Anyone Want To Buy A Van......?
Page 2 of 2 Previous  1, 2
Re: Anyone Want To Buy A Van......?
Post by Logi on Tue Apr 26, 2016 5:52 am
Just thought, is there a cutoff switch?
Probably best to try the simple steps first
If not, Matt, did you have a pump?
Post by HighlyJetted on Tue Apr 26, 2016 7:50 am
Sorry, looked yesterday, no new pumps Sad
No inertia cutoff switch to my knowledge.
Post by PFM on Tue Apr 26, 2016 8:17 am
Is your pump definately getting power, Logi?
Post by Logi on Tue Apr 26, 2016 3:00 pm
HighlyJetted wrote:Sorry, looked yesterday, no new pumps Sad
Sad
Post by Logi on Tue Apr 26, 2016 3:04 pm
PFM wrote:Is your pump definately getting power, Logi?
Tbh I've not looked at it, too much on just now, it's not looking like it'll get anything done for the next few weeks either, I'm away this weekend and next is my local classic car show so I need the garage clear to fettle the Jag and the Merc in readyness.
Really awkward time for it to fuck up Sad
Post by HighlyJetted on Thu May 12, 2016 7:04 pm
Do you still need a new pump?
New batch of 20 has turned up from Germany
Post by Logi on Thu May 12, 2016 9:12 pm
Possibly, haven't bothered my arse looking at it, been sunny so I'm mostly doing this.
Post by Logi on Fri May 13, 2016 2:06 pm
Pm me with a price, looking like the weather is turning pish, so will be in the garage.
Post by GEORDIE on Fri May 13, 2016 3:11 pm
Bollocks to the cost,get one bought you tight arsed Scot and get your "beloved" Jet on the road again!
Has anyone heard from Woody lately,hope he is ok??
GEORDIE
Post by HighlyJetted on Fri May 13, 2016 5:06 pm
Yes woody is pretty good, just been given the all clear to drive again.
Post by GEORDIE on Fri May 13, 2016 11:05 pm
That is good news
GEORDIE
Post by Logi on Sat May 21, 2016 5:34 pm
Well, the van lives(though nearly got the shit kicked out of it)
Dropped the tank, thought I might as well try 12v direct to the pump, guess what?
It fuckin pumps, every single fuckin time.
Having better access to the wiring I checked the feed again, works perfectly, shuts off after set time, works on cranking. No issue with the relay.
Anyone want to guess?
Post by HighlyJetted on Sat May 21, 2016 7:17 pm
Oh bollocks! And you bought a fucking pump!!!
Its the golden checks time:-
Pull out coil pack/ht lead number one - put an old plug in the end - touch it to the head - do you have a spark when you crack it over?
Put a long screw driver onto an injector and put your ear on the screwdriver handle - can you hear the tick noise of the injector when you crank it over?
Post by Logi on Sat May 21, 2016 7:28 pm
Nope, not ignition related
Anyone want to buy a pump.......
Post by HighlyJetted on Sat May 21, 2016 8:08 pm
Post it back to me if you need.
Post by PFM on Sat May 21, 2016 8:19 pm
Blocked filter or collapsed hose?
Post by Logi on Sun May 22, 2016 5:19 am
None of the above.
I checked the voltage at the plug above the tank( which was correct) I also powered the pump through the other side of the plug( which worked)
I decided that I'd just run a separate ignition fed wire to power the pump. I chopped the end of the wires and just thought I'd try reconnecting them without the plug( which showed voltage on one side, powered the pump at the other and looked perfect)
Hey fuckin presto.
Somehow when connected the plug wasn't conducting electricity.
Matt, I'll pm you. Cheers.
Post by Raggy on Sun May 22, 2016 6:58 am
Presume the connectors had just got corroded, glad you got it going.
Post by Logi on Sun May 22, 2016 11:19 am
Nope, looked perfect, no corrosion whatsoever. Evil or Very Mad
Post by Raggy on Sun May 22, 2016 12:39 pm
Oh well, another Hijet mystery! Main thing is that its going again.
Post by Logi on Sun May 22, 2016 3:22 pm
Gave it a wee treat, not that it deserved it, Rolling Eyes
Put a new wheel on the Merc, this is too dark for the Jag
Post by Logi on Mon May 23, 2016 9:56 pm
HighlyJetted wrote:Post it back to me if you need.
Tis winging it's way home, Smile
