bad running/ Problem solved!
Post by jeremiah1992 on Thu Apr 07, 2016 9:00 pm
Hi there,
December i replaced my engine for a good used one, drive it every day a 10km run in the morning and 10km run afternoon and a lot small trips on the other days.
It runs great, had problems with an ignitioncable that came loose from the bobine to the rotorcap, pushed it back and went well.
Till today, this morning I wanted to drive the car but it died after start, with the gas i kept it on, but loosen the gasthrottle and it died. I arrived at my destination and in the afternoon it took me to 1km ahead from my home, it died at the trafficlight and the accu ran out power so it didnt start.
Someone helped me to start it again, and using the handbrake an keep the foot on the gas i arrived at home.
Did a direct check up
Oil good
Coolant good
Accu good, checked it with a diagnose system, it had 269A from the 300A left with a 12,78 Voltage.
Just changed my spark plugs, didn't help.
Increased idle speed with screw, engine kept running.
Engine runs bad, started to smoke and smell from the exhaust.
Someone some help to check some things or tips?
jeremiah1992
Re: bad running/ Problem solved!
Post by HighlyJetted on Thu Apr 07, 2016 11:09 pm
1.3 or 993 ?
Post by jeremiah1992 on Sun Apr 10, 2016 10:03 am
993, distributercap is good, can it be carburatorissues? Like fuel. I just drove with it, kept the shoke in position 4 and idlespeed high, and it runs smooth then, only with too high rpm
jeremiah1992
Post by jeremiah1992 on Thu Apr 14, 2016 4:13 pm
problem solved, keycontact didn't work optimal, now its fixed temporarely and it runs like a dream again, now looking for the bad cable that causes the trouble
jeremiah1992
