odd idle speed
odd idle speed
Post by leopard_pagan on Fri Jan 28, 2011 6:28 pm
got two odd things happening on my wee van.
in the mornings i am finding the choke running higher than usual in the first 2-3 minuets from cold start.
after the vans all warmed up and i am getting near/to work/home, the idle speed starts revving high, then drops, then high and drops again but as soon as i engage the gears/clutch and pull away the idle stays steady. only does it when stood still waiting in traffic or just as i pull up to park.
any ideas what i need to start poking n prodding?
Re: odd idle speed
Post by leopard_pagan on Sun Jan 30, 2011 9:32 am
so contenders are:
Automatic choke
Idle speed sensor
Lamber sensor?
mines a EFI model.
Re: odd idle speed
Post by PFM on Sun Jan 30, 2011 1:31 pm
Is it low on water?
Re: odd idle speed
Post by leopard_pagan on Sun Jan 30, 2011 6:51 pm
i checked water a week ago as 4 months ago i re-did the head gasket/skimmed head etc..
i'll recheck again in the morning
Re: odd idle speed
Post by leopard_pagan on Mon Jan 31, 2011 5:19 pm
water levels are fine, if anything the over flow bottles a bit over the line.
located the throttle sensor under driver seat.
just need to locate the auto choke to check it.
Re: odd idle speed
Post by PFM on Mon Jan 31, 2011 7:13 pm
OK - and I take it you checked at the radiator as well. Sorry can't offer anything further - I've only had the same symptoms when water level has been low.
Re: odd idle speed
Post by rich the mechanic on Mon Jan 31, 2011 9:21 pm
It hasn't got a auto choke its EFI, there is a cold idle circuit that is controled by the temp sensor and ECU check the plug by the dizzy make sure its clean and dry.
Re: odd idle speed
Post by leopard_pagan on Tue Feb 01, 2011 6:16 pm
no auto choke.... well that explains why i cant find one in the manuals or any ref to one..lol just put it down to crappy manuals!
will route around the dizzy area tomorrow lunchtime checking plugs n things.
i do know my sodding cyl 2 HT lead keeps on dropping off the spark plug! i lost count how many times i fitted/removed the plugs a few months ago while doing the head job! and i couldent get the pliers in to bend the tube inside! couldnt bend from out side as hands arent strong enuf!... need a burly man for that job!
Re: odd idle speed
Post by simmo116 on Tue Oct 01, 2013 6:57 pm
hi sorry to bring up the past but did you solve your problems leopard_pagan?
simmo116
Re: odd idle speed
