Hi-Jet Pick-up Project..
Page 1 of 3 1, 2, 3  Next
Post by CycleKart UK on Wed Apr 20, 2016 10:32 pm
Well if i can get some photo's uploaded  ... yeh!!! This is the hole i need a cover for...
CycleKart UK
http://www.cyclekart.co.uk
The destruction starts
Post by CycleKart UK on Wed Apr 20, 2016 10:43 pm
CycleKart UK
The shopping list is getting longer!!
Post by CycleKart UK on Wed Apr 20, 2016 10:46 pm
CycleKart UK
Post by CycleKart UK on Wed Apr 20, 2016 10:53 pm
The seat bases were a little rusty underneath so they got a quick coat of POR15 anti-rust primer by the resident artist !!
Note to self "I must get the grass cut..."
CycleKart UK
Re: Hi-Jet Pick-up Project..
Post by Woodie on Thu Apr 21, 2016 6:59 am
Looks like you might be needing a few more bits and pieces then. Don't be afraid to ask. Love it. Oh sorry forgot to add. That's after Doctor Logi says that I can go back to work of course. Bless him!! Shocked
Post by Raggy on Thu Apr 21, 2016 12:34 pm
Brilliant, keep the thread updated so we can see how you are getting on.
Post by scotia on Thu Apr 21, 2016 4:32 pm
nice to see youre fixing it up.
keep the updates comming Smile
Post by Logi on Thu Apr 21, 2016 5:52 pm
You're a lot younger than I imagined...... Wink
Post by CycleKart UK on Fri Apr 22, 2016 4:26 pm
Laughing
CycleKart UK
Post by CycleKart UK on Fri Apr 22, 2016 5:16 pm
Seat bases painted black
CycleKart UK
Post by CycleKart UK on Fri Apr 22, 2016 5:19 pm
Seats and carpets cleaned
CycleKart UK
Post by CycleKart UK on Fri Apr 22, 2016 5:24 pm
The wife was in London today so i took the opportunity to do some baking, no soggy bottoms here  Wink
CycleKart UK
Post by Logi on Fri Apr 22, 2016 6:00 pm
There's a good write up on a stateside forum about replacing pickup seats, cos they're not as easy as van ones .
Post by CycleKart UK on Fri Apr 22, 2016 6:25 pm
Have you got a link to it or the forum name Logi?
I've got 10 mins spare while the headlamp lenses are in the dish washer... Very Happy
CycleKart UK
Post by Logi on Fri Apr 22, 2016 7:02 pm
Guy called Fupabox, here's the steering wheel thread, can't find the seat one
https://minitrucktalk.com/threads/aftermarket-steering-wheel-hijet.5261/
Post by CycleKart UK on Fri Apr 22, 2016 7:23 pm
Found it , cheers Logi, will read later, the wife is back..got to empty the dish washer..sneaky like..
CycleKart UK
Post by PvdB on Tue Apr 26, 2016 6:05 pm
Hey,
I found your topic! I see that you also got an extra pair of hands. But please, don't pay her with beer, like I me for my dad Wink
Your Pick-up doesn't look that bad. Hopefully no problems for MOT after you fixed your head lights. It is a very common problem. But is it cheaper to fix it like this then buy a good second hand replacement head light?
(Here in Holland I've payed 50euro max)
Keep up the good work and can't wait to see your progress and the ideas that you have in mind!
PvdB
Post by CycleKart UK on Tue Apr 26, 2016 7:52 pm
Ha Ha...her Mum might have something to say if i did Smile
Sooo in between snow showers i managed to fit the screen....a very unremarkable photo below (note bright sunshine...trust me it snowed 10 mins later) Please note the absence of any cracks running horizontally long the bottom of the screen.
CycleKart UK
Post by CycleKart UK on Tue Apr 26, 2016 8:11 pm
Now that the screen is in i can start to put the dash back in,  having fitted a new wiper motor and linkage and a new column switch/stalk assembly i thought it prudent to check the electrics....
lights..check
wipers..check
horn...check
washers...pump made a sound then water started dribbling down the bulkhead...blocked washer jet caused the pipe to blow off...easy fix with a strand of copper wire...check
Start the engine and let it warm up...run inside the house as it snowed heavily...
Snow stopped so back to the pick-up to check engine temp and heater/fan operation..nothing ...nada...neit..nowt...
I had noticed a coupe of loose connectors hanging around , so i tried to locate the fan plug to see if one of them matched up....can you spot the obvious?
CycleKart UK
Post by CycleKart UK on Tue Apr 26, 2016 8:20 pm
I've had a quick search on ebay and found a couple of Fan Motors...can someone confirm that all non-aircon models are the same..mines a 2001. I'm looking at item number 331114651572
CycleKart UK
Post by CycleKart UK on Tue Apr 26, 2016 8:43 pm
Couple of pics of my newly refurbished headlight internals :-
before
After
CycleKart UK
Post by PvdB on Tue Apr 26, 2016 11:10 pm
CycleKart UK wrote:I've had a quick search on ebay and found a couple of Fan Motors...can someone confirm that all non-aircon models are the same..mines a 2001. I'm looking at item number 331114651572
I don't know the item number, but the picture above looks pretty familiar.The older 1.0l engine and the newer 1.3 use the same fan. So try to find one at your local junkyard if possible.
And yes, it is obvious Wink
PvdB
Post by HighlyJetted on Wed Apr 27, 2016 7:59 am
CycleKart UK wrote:Couple of pics of my newly refurbished headlight internals :-
before
After
What did you use on they head lights? They look great!
Post by CycleKart UK on Wed Apr 27, 2016 9:40 am
before
After
Very Happy lets see if it passes a mot before i tell you...i'm fairly optimistic reflecting on how i did it Smile
CycleKart UK
Post by CycleKart UK on Wed Apr 27, 2016 10:54 am
Fan ordered off the Bay of E...should be here Tomorrow or Friday...then i can continue to install the dash..
CycleKart UK
Post by CycleKart UK on Wed Apr 27, 2016 10:02 pm
Tonight I re-fitted the glass to the headlights...
CycleKart UK
Post by HighlyJetted on Wed Apr 27, 2016 10:03 pm
They look mint, will pass an MOT for sure 100%
Post by CycleKart UK on Sun May 01, 2016 7:31 pm
Had a little time today between rain so i got on with putting the guts back in the Pick-up.
Fitted the new fan that i sourced on E-bay, installed the wipers and wiper arms and discovered that the washer pump was blocked. I had a quick look and found that the washer pump is removable from the reservoir. I reached in through the passenger seat side and twisted the pump down to release it from the horseshoe clip and just levered the pump out of the reservoir, it is secured in with a sealing grommet....the smell was revolting and gunge that can out looked like it had its own life force. The problem was self evident as the gauze on the pump was blocked with gunge. A quick rinse under the hot water tap and everything was put back in true Haynes manual manor ie "reassembly is the reverse of removal"...result working washers.
  I refitted the dash and most of the plastics, refitted the carpet ( this has had a couple of washes and vacuums...it looks like a carpet now rather than a dried river bed) then installed the headlights ( i'd sorted out the reflectors last week) headlight trim and finally indicators.
 It occured to me that i'd never ran the engine up to temp. I'd bought the pick-up knowing most of its issues and was assured that the engine was sound. However i thought it about time i found out for myself....and its okay. left it running for 1/2 an hour, it got up to temp. the fan kicked in all pipes warm, no leaks or anything untoward...bonus. I'll keep an eye on things obviously but at least i don't have to put a motorcycle engine in yet :-)
Now ensues the obligatory pics :-  ( hold your excitement )
CycleKart UK
Post by Raggy on Sun May 01, 2016 8:48 pm
Very tidy van! Just down the road from me as well.
Post by CycleKart UK on Sun May 01, 2016 10:51 pm
Cheers Raggy, but I think the photo's are making it look better than it is...I'll keep an eye out for you, you should be easy to spot..
CycleKart UK
