Jack, spark plug cables, draft..
Post by tornas on Sat Apr 23, 2016 8:50 pm
Got my first lesson in car mechanics today! Interesting to learn a bit about how my car.
During the course we encountered a few things that the instructor wasn't sure about. It's miscellaneous stuff so I'll put my questions here. Would be cool if you guys could give me some feedback Smile
The jack...
First of all, my gf tried jacking the car up with what seemed to be the original jack (same as this one), but the jack could barely reach high enough to lift the car. When she put it under the car and cranked it up to its max height, the jack snapped and the bearing broke. It's beyond repair. So.. what did we do wrong? And when I buy a new jack, should I go for an original (which I would prefer if it's not inferior) or for another?
The spark plug cables...
This was a weird one. The previous owner gave us an old spark plug cable that he still had. That one looked wayyy different than the ones that are installed in the car now:
Those aren't the right ones are they? Any recommendations on which ones to use?
The draft...
This one's been talked about alot on this forum: the draft coming from the flimsy headlight cover... I'm thinking about drilling a small hole in it and in the chassis to fix it with a bolt or a cable tie. Would you recommend this or is there a better option?
tornas
Re: Jack, spark plug cables, draft..
Post by tornas on Sat Apr 23, 2016 8:57 pm
Oh and one other thing:
My van has panel doors but I want doors with windows. When I told the garage manager I was thinking about buying other doors, he told me that I should just find somebody who can fit windows in the current doors. Says that's less risky. What do you think?
tornas
Post by scotia on Sun Apr 24, 2016 7:50 am
just get another jack thats a bitt better.
something like this, thats easy to take with you in the van.
i think they cost about 35-50 euro
or this would even be better
Post by HighlyJetted on Sun Apr 24, 2016 9:05 am
The spark plug cables = HT Leads :- The one in the photo is incorrect.
The draft :- Yes, add fixings/screws to the top - this will cure most of the draft
The jack:- In 12 years of Hijet ownership, I have never had to or wanted to use the emergency jack.
Post by tornas on Sun Apr 24, 2016 9:27 am
Cables & draft: noted, thanks!
Jack: I see.. What do you do when you have a flat tire?
And I'm curious about your opinion on the doors?
tornas
Post by HighlyJetted on Sun Apr 24, 2016 9:38 am
Flat tyre - not had that problem yet. When I change wheels and tyres at home/work I use these, which I have a pair of http://www.ebay.co.uk/itm/Arcan-2000kg-Aluminium-And-Steel-Service-Jack-Model-HJ2000EU-/111950985911?hash=item1a10cc7ab7:g:QoIAAOSwLpdW-b-t
Finding doors in the correct colour shade, and in ideal condition can be difficult. But genuine rear doors have wind up/wind down windows - these winders ALWAYS fail. If you get the doors cut and glass fitted they will either be non openers, or they will have sliding sideways glass. I would expect a glass firm to charge around £400 to £500 to supply and install rear windows (at a guess).
Post by tornas on Sun Apr 24, 2016 9:45 am
OK thanks for the advice, much appreciated.
tornas
Post by Logi on Sun Apr 24, 2016 10:11 am
Post by tornas on Sun Apr 24, 2016 11:04 am
that's a bit more within my budget range Wink
tornas
Post by scotia on Sun Apr 24, 2016 11:45 am
tornas wrote:that's a bit more within my budget range Wink
youre realy dutch arent you Laughing
i thought 35 euros for the litle jack was a good deal.
comes in a handy case which you can take with you in the van...
the kind of jack HJ posted i use at home to.. those are verry good but expensive and come in handy when you own low cars to Smile
Post by tornas on Sun Apr 24, 2016 11:48 am
35 euros is not bad! But I wouldnt even know where to put that thing that HJ posted. I'm not only the proud owner of a microvan, I also live in a micro-apartment.
tornas
Post by Woodie on Sun Apr 24, 2016 1:57 pm
I have exactly the same set, Jack, Folding Axle Stands and Folding Wheel Chocks in the plastic case.  I  bought a year ago from Screwfix.
I got it for my Romahome before I went off down to Sidmouth in Devon last June. It fits neatly into the under seats bunk storage lockers. Really worthwhile addition to the Tool kit.
Post by tornas on Sun Apr 24, 2016 3:07 pm
HighlyJetted wrote:The spark plug cables = HT Leads :- The one in the photo is incorrect.
So I've been googling for the right ht leads but can only find cables that more or less look like the ones that are in my hijet right now (I think they're suited for older models?). Any advice on which brand/type I should use?
tornas
Post by Lex_Michdebus on Sun Apr 24, 2016 5:00 pm
For a cheap jack you should also keep your eye on the Aldi and Lidl. They are often selling acceptable jacks for an acceptable price. Where to put it? Just throw it in the back of your van! They also had cheap 2 ton axle stands the other day, 20 euros for a pair if I recall correctly.
About the spark plug cables: have you tried carpartsdirect.nl already?
Also; post videos of you girlfriend jacking please!
Lex_Michdebus
https://youtu.be/zAH2jjzAhU8
Post by Woodie on Sun Apr 24, 2016 5:06 pm
At your age Lex you should change your name to Lex Missed-de-bus. Dirty old man. No
Post by Lex_Michdebus on Sun Apr 24, 2016 5:32 pm
What? I've seen mine jack it so many times... I need something new now and then.
Lex_Michdebus
Post by tornas on Sun Apr 24, 2016 5:40 pm
Oh how many jokes I made yesterday about 'krikken in de bus'!
tornas
Post by tornas on Sun Apr 24, 2016 5:43 pm
On topic:
Nothing, Lex Sad
tornas
Post by Lex_Michdebus on Sun Apr 24, 2016 5:51 pm
Bummer. They have a set suitable for my version (1996, 993cc carb.), but I guess they're not right for yours. What's your license plate number? That way I can check other websites. (You can send it in a PM if you're uncomfortable with having it out in the open, same goes for the video)
-edit- https://www.winparts.nl/motordelen-toebehoren/bougie-kabels/daihatsu/hijet-bestelwagen-s85-bouwjaar-1992-12/c1180-554-14146/bougiekabelset/p327122.html
These perhaps? They don't have it in stock... And I don't know about the brand Blue Print.
-edit2- https://www.dutchcarparts.nl/15797-daihatsu-hijet-van-13i-16-v-kat-1998-/auto-onderdelen/motor/ontsteking/bougiekabel
Nipparts, I would trust those. But again, you'll have to email them about it.
-edit3- http://www.mijnautoonderdelen.nl/daihatsu/hijet/65971/65977/bougiekabelset
Again Nipparts, again "op aanvraag", send them an email. I searched for the parts that fit a Van with 1.3 16v engine.
-edit4- The Nipparts part number: N5386018. That should help you finding it better, perhaps on eBay or Amazon.de?
Lex_Michdebus
Post by tornas on Sun Apr 24, 2016 7:42 pm
Ah yes that number helps. Posted a few requests here and there so I'll have to wait.
It seems that the cables that are in my car now fit some 993 models. If you want I could send them to you when (if) I find myself proper cables. So far the engine's starting and running perfectly fine with em btw Smile
I'll send the video via PM.
tornas
Post by Lex_Michdebus on Sun Apr 24, 2016 8:06 pm
Throw them in your parts bin, you always need parts when you fix your own cars.
The websites I tried:
http://carpartsdirect.nl/
http://www.besteonderdelen.nl/
https://www.winparts.nl/home
http://www.onderdelendirect.nl/
http://www.easycarparts.nl/
I'd advise you to create a folder named "Auto-onderdelen" and put those websites in there. Then when you need parts, start from the top.
Great video by the way, that gf of yours has one strong and firm grip on her that's for sure!
Lex_Michdebus
Post by scotia on Mon Apr 25, 2016 7:33 am
Post by tornas on Mon Apr 25, 2016 8:52 am
Wow, that is expensive. They have spark plug cables for the first en second cylinder (didn't know there's a different one for every cylinder) and each is around € 90. So that'd be €360 for four. Sounds a bit steep!
And no cables for the third en fourth cylinder? Or is it only the first cylinder that needs a different one? Getting lost now!
tornas
Post by scotia on Mon Apr 25, 2016 1:59 pm
i didnt look for cables on their site it was more to add to your carparts suplier list
i think its a fault on their site... that doesnt make sense indeed  Neutral
but they have got a lott of other specific parts so put them in your partsdealerslist Wink
sometimes you can copy the partsnumber from an expensive site.. then copy and paste it in your google and it will give you more sites with the same parts, like lex did
