Multiple misfires
Multiple misfires
Post by Steveincornwall on Tue May 03, 2016 7:02 am
My 2008 1.3 porter (1100 miles) showed engine management light yesterday. I checked the codes with a reader and it said cylinder 2 and 4 have multiple misfires, even though as far as I am aware it hasn't missed a beat.
Any ideas, my thoughts: change plugs, leads and coils if needed?
Steve
Steveincornwall
Re: Multiple misfires
Post by HighlyJetted on Tue May 03, 2016 7:38 am
Reset it, see if/when it comes back.
Write down the exact code number, as the piaggio/daihatsu definitions might be different from generic obd2 definitions.
Post by PFM on Tue May 03, 2016 1:28 pm
1,100 miles in 8 years? Sounds like it needs a good run!
Post by Steveincornwall on Tue May 03, 2016 2:03 pm
HJ thanks for you help, I cleared the codes and gave it a run, just checked and it is no longer showing any errors. I will keep an eye on it and see what happens.
Should be 11,000. Pickup spent its previous years on a RAF base and was used to collect and pick up spares. Gave it a good run when I bought it and have added a 1000 miles since.
Steve
Steveincornwall
Post by Steveincornwall on Mon Jun 13, 2016 7:22 am
Changed plugs and misfire went away for a few weeks. Light came on again at weekend, this time reader says 1,3 and4 (P0301,P0303andP0304) are misfiring! Although pickup appears to run fine it seems to happen when under load i.e. when in wrong gear.
Any advice welcome?
Steve
Steveincornwall
Post by HighlyJetted on Mon Jun 13, 2016 10:28 am
Compression test it.
Is it LPG ?
Post by Steveincornwall on Mon Jun 13, 2016 12:25 pm
No not LPG, will check compression. All a bit odd as I can drive 100+ miles without any problem, then management light comes on!
Steveincornwall
Post by HighlyJetted on Mon Jun 13, 2016 2:17 pm
Might have a dodgy igniter box - its bolted onto the rocket cover.
