Running on 3 cylinders
Post by duckpits on Fri May 27, 2016 11:54 am
Hi, I am a Newbee
My Hijet is running on 3 cylinders, its not compression, its not the coil pack and its not the plug. At one stage it came on to 4 cylinders when I lifted the plug lead off the plug. It has overheated in the past but new rad has sorted that
HELP
duckpits
Re: Running on 3 cylinders
Post by scotia on Fri May 27, 2016 12:13 pm
have you checked the spark plugs?
Post by duckpits on Fri May 27, 2016 1:03 pm
cleaned and swapped round, made no difference
duckpits
