I want a constant 12V-15A connection, where to get it from?
Post by Lex_Michdebus on Mon Jun 06, 2016 12:13 pm
So I bought some stuff I'm probably never going to use to put in the van and I want to be able to connect it to a constant 12V source. This will also give me a constant 12V source for my radio, so it'll keep everything in memory etc. The standard radio/cig's connection is switched.
Where would you get it from? Behind the fusebox? I want it to be close to the radio, so getting it straight from the battery would be a little shite because of the distance of new wire that I'm going to need to get over there.
Lex_Michdebus
https://youtu.be/zAH2jjzAhU8
Re: I want a constant 12V-15A connection, where to get it from?
Post by HighlyJetted on Mon Jun 06, 2016 7:08 pm
There is a heavy gauge permement live cable to the ECU in the passenger footwell
Post by Lex_Michdebus on Mon Jun 06, 2016 8:56 pm
HighlyJetted wrote:There is a heavy gauge permement live cable to the ECU in the passenger footwell
Ah, perhaps it is necessary to tell you all I have one without ECU...
Lex_Michdebus
