Replacing water pump neccesary when replacing Timingbelt, Porter 1.3
Post by Manuel_nl on Sun Jun 12, 2016 12:08 pm
No I'm not doing this myself but I just want to know
The timing belt is not running across the water pump so I would say ... leave it.
But what do the most of you people do. Replace it in advance?
Manuel_nl
Re: Replacing water pump neccesary when replacing Timingbelt, Porter 1.3
Post by Raggy on Sun Jun 12, 2016 12:28 pm
I had mine done at same time as it was of unknown age and while one being done down there it was just as easy for garage to do pump and belt a same time. I did have however other work done at same time.
Post by Lex_Michdebus on Sun Jun 12, 2016 5:07 pm
On the 993cc engine the water pump is behind the belt. It's not driven by it, but to get it off you need to remove the timing belt. So on a 993cc it's best to do it at the same time, because when changing the belt, you're only 5 minutes away from a new and fitted pump.
The 1.3 is a different engine, so I wasted a few seconds of my life writing this, but I guess it will end up in the search one way or another.
Lex_Michdebus
https://youtu.be/zAH2jjzAhU8
Post by Raggy on Sun Jun 12, 2016 5:27 pm
Well done sir! Mine was a 993 so you are correct.... I have absoluetly no exprience or idea about a 1.3 Very Happy
