Doesn't Seem Dear?
Doesn't Seem Dear?
Post by Logi on Tue Jun 14, 2016 6:51 pm
Re: Doesn't Seem Dear?
Post by Raggy on Tue Jun 14, 2016 7:33 pm
No, could be cheap for some spares or if you up to fix problems and they are not expensive?
Reason(s) for failure
Parking brake: efficiency below requirements (3.7.B.7)
rear Brakes imbalanced across an axle Axle 2 (3.7.B.5b)
nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Brake fluid warning lamp illuminated (3.6.G.2)
Brake hydraulic reservoir fluid level below minimum level (3.6.G.1b)
offside Headlamp aim too low (1.Cool
offside Stop lamp not working (1.2.1b)
offside front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
nearside rear Hydraulic brake cylinder leaking hydraulic fluid (3.6.A.1)
Exhaust has a major leak of exhaust gases (7.1.2)
Exhaust system not adequately supported (7.1.1)
Emissions not tested exhaust system incomplete (7.3.A.1)
nearside rear Suspension spring mounting prescribed area is excessively corroded front and rear mountings (2.4.A.3)
offside rear Suspension spring mounting prescribed area is excessively corroded front and rear mountings (2.4.A.3)
offside rear Leaf spring eye defective (anchor) (2.4.B.1b)
Advisory notice item(s)
corrosion close to o/s/f engine mounting
Post by HighlyJetted on Tue Jun 14, 2016 9:35 pm
So it needs:-
Rear brakes + lspv sorting
Front wiper blades
An Exhaust sorting
Both rear inner arches welding
One rear leaf spring
Welding on the front chassis box section or lower inner under carbon bottle.
Then it might pass an MOT.
But will still look like a shagger as the silver paint is falling off as always!
Post by Raggy on Tue Jun 14, 2016 10:00 pm
Exactly why its so cheap, lots to do, far outweighing cost of fixing.
