660 to 993 engine upgrade
Post by ttc on Tue Jun 21, 2016 8:33 am
Hey guys I have been working my hyjet pretty good hauling lots of stuff and often wonder would swapping a 993 in make much of a difference. I find on big hills the truck slows to 80kph but on the flat I can buzz along at 100 kph but seldom do. I like to keep it around 90. I have had it up to 110 once but was worried I was reving the engine a tad bit much. What is the actual red line on a 660 and a 993?
ttc
Re: 660 to 993 engine upgrade
Post by Raggy on Tue Jun 21, 2016 9:11 am
Think the general concensus would be its not worth it or I stand to be corrected not feasable. You'd be better off selling the current one and getting a 1.3 plus you would have the problem of getting a good 993 engine to put in anyway.
Post by ttc on Tue Jun 21, 2016 9:20 am
Oh I should add I am in Canada and options are slim. Does the 1.3 rev up like the 660?
ttc
Post by Raggy on Tue Jun 21, 2016 9:35 am
Hmmm not a clue on that one! HighlyJetted may have some idea on that one. Whats the availability for 993 and 1.3 hijets in Canada?
Post by ttc on Tue Jun 21, 2016 10:01 am
Hens teeth. I imported mine from Japan. They never sold them here.
ttc
Post by Raggy on Tue Jun 21, 2016 10:18 am
Ah! That could be your main problem then!
Post by ttc on Tue Jun 21, 2016 10:40 am
The charade and rocky where sold in the late 80 to 92
ttc
Post by ttc on Tue Jun 21, 2016 11:22 pm
Because we boarder merica in all its greatness everything we get is American size. Vw was one the only manufactured selling diesel cars here unless you had the quid for a merc. We dont get the model options like the rest of the world.
ttc
Post by scotia on Wed Jun 22, 2016 8:35 am
if it can be done i also think its not worth the money and you could better sell it and buy something with some more hp.
there is an other forum that has more of your type of hijet.
and is based in north america.
i think they will have more answers for you..
https://minitrucktalk.com/
Post by ttc on Wed Jun 22, 2016 9:59 am
What can I bomb down quad trails in a cab with ac and tunes. Then pull onto public streets and drive legally. I own 56 acers of land i also use it on. It has a dump box that I can haul say a deer out of the back woods in or pop to the local lawn and garden center am take home a yard or 2 of soil. Oh and I am on mini truck talk also.
ttc
Post by Raggy on Wed Jun 22, 2016 10:02 am
So you only have a small back yard then! Got to have pictures of the hijet and its backyard!
Post by scotia on Wed Jun 22, 2016 11:49 am
ttc wrote:What can I bomb down quad trails in a cab with ac and tunes. Then pull onto public streets and drive legally. I own 56 acers of land i also use it on. It has  a dump box that I can haul say a deer out of the back woods in or pop to the local lawn and garden center am take home a yard or 2 of soil. Oh and I am on mini truck talk also.
i dont know...im from the netherlands..i dont know the north american market.. Neutral
if you are already a member there and didnt get the info
chances are verry small you will get them here
i cant help you ,maybe somebody else will give you the right answers
Post by ttc on Thu Jun 23, 2016 12:00 pm
i asked here vs minitruck talk because most of what we have here is imported from japan and only have the 660, you guys across the pond got the 993 and the 1.3 Smile
ttc
Post by scotia on Thu Jun 23, 2016 3:46 pm
i think there are a lott of questions regarding an engineswap
-will it fit your gearbox?
-enginemounts are probably different
-how will you get parts if something brakes down?
-the 1.3 does suffer a lott from overheating, it would suck if you go tru all the effort and then have an overheating engine pale
-the 993 is difficult to get parts i think
if you imported it from japan could it be an option to look for a same type or something near the same
buildyear that has a turbo.
and import that engine..
i think you can probably forget an easy swap with an 993 or 1.3 ..
Post by HighlyJetted on Thu Jun 23, 2016 7:27 pm
Tell me more about which hijet you have?
What is the model code on the vin number plate?
What engine code is yours?
Post by ttc on Thu Jun 23, 2016 11:46 pm
95 s110p and i am pretty sure it has a EF-NS i can get the info in a bit
ttc
Post by scotia on Mon Jun 27, 2016 9:19 am
the ef series has got a lott of different options..including turbo
Post by PvdB on Mon Jun 27, 2016 11:08 am
scotia wrote:the ef series has got a lott of different options..including turbo
Is there actual anyone who turbo charged his hijet?
PvdB
Post by scotia on Mon Jun 27, 2016 2:08 pm
there are loads of standard tubo versions straight from the factory patrick
Post by PvdB on Mon Jun 27, 2016 4:13 pm
Ah of course, the Japanese versions (kei cars) with the 660cc engines. Was thinking to much European Razz
But are there also 1.0EFI and 1.3EFI hijets with turbo?
PvdB
Post by ttc on Mon Jun 27, 2016 7:59 pm
The biggest ? Was if the bell housing on all 3 engines was the same. I know some other manufactures design this way for makes it cheaper for tooling cost and setup
ttc
Post by scotia on Tue Jun 28, 2016 9:04 am
PvdB wrote:Ah of course, the Japanese versions (kei cars) with the 660cc engines. Was thinking to much European Razz
no, maybe some custom jobs but not standard from the factory.
ttc wrote:The biggest ? Was if the bell housing on all 3 engines was the same. I know some other manufactures design this way for makes it cheaper for tooling cost and setup
i dont know ttc, you should investigate that
i know a lott daihatsus are interchangeable with parts so there is a chance it could work.
Post by Woodie on Tue Jun 28, 2016 9:22 am
The 1300, 993cc and Diesel bellhousings are all different.
Post by ttc on Tue Jun 28, 2016 4:32 pm
Hmm so leaves me to wonder if the 660 and 993 might be the same. Guess I may have to ask more on a forum from down under they get a lot of Japanese stuff and imports
ttc
Post by HighlyJetted on Tue Jun 28, 2016 4:46 pm
660 and 993 are compatible I think.
Never tried, but they should share the same bell housing.
993 would be better than the engine you've got, but they aren't the greatest of units!
