water leak?
water leak?
Post by bulldoguk on Tue Jul 26, 2016 7:02 pm
hi i have a 2004 extol with the 1.3 yaris engine in it.noticed it was dripping water today at work had a quick peek seems to be coming from the water pump? is this normal or is it terminal for the water pump?(it is getting bit noisy) plus how easy is it to do ? many thanks in anticipation of some skinned knuckles no doubt Question
bulldoguk
Re: water leak?
Post by PFM on Wed Jul 27, 2016 1:37 pm
You may have noticed there are not many Extol's on here - I wasn't keen on the one I had and prefer the Hijet/Porter. It's not normal for the pump to leak, but where is it coming from? If round the edge of the body you might be able to bodge a seal, but if from the pulley shaft (likely as it's getting noisy) it's probably terminal. A closer look is in order.
