Steering column movement, Common?
Post by 8bit-ash on Mon Feb 28, 2011 4:06 pm
Had my MOT today which the van failed on excessive steering column bearing wear. (plus other stuff) Before I pull it apart and have a look I thought i'd see if movement is normal as they're so basic.
I just have a bit of movement of you wiggle the steering wheel side to side.
Re: Steering column movement, Common?
Post by PFM on Tue Mar 01, 2011 7:21 pm
No movement on either of mine, sorry.
Post by 8bit-ash on Thu Mar 03, 2011 1:07 pm
Cool, the one at the scrapyard I tried had the same movement but its failed anyway so i've ordered a new bush at a shocking £32.
Post by rich the mechanic on Mon Mar 07, 2011 10:05 pm
ouch Exclamation
