Radiator cap/ expansion chamber cap
Post by Tukz on Sat Mar 05, 2011 9:53 pm
Which is which??
Whilst the rebuild was taking place, the caps got removed and now I am not sure that we have them the right way round. I have the flat one on the radiator and the pressure release one on the expansion chamber. Is this the right way????
Tukz
http://www.tuktuktravel.co.uk
Re: Radiator cap/ expansion chamber cap
Post by PFM on Sun Mar 06, 2011 12:40 pm
Flat one on rad, yes - spring cap goes on rail at top of engine - though if you've changed to a pressurised expansion vessel it should probably go on that.
Post by LloydAJN on Fri Oct 28, 2016 3:36 am
Spring Caps should be able to go on both, but the cap under the passenger seat has to be a sprung one.
LloydAJN
