Broken clip on radiator cover
Post by rjdutch on Thu Mar 10, 2011 7:18 pm
Hello all, I'm new to the forum as I have just recently purchsed a 1996 Hijet.
I have an early problem however which i guess must be quite a common one! The clip on panel covering the radiator has had its lower two clips broken by the last owener and replaced by..............gaffer tape! affraid
Clearly I need to replace the clips. Does anyone know where I could get some from, or know of anything I could use instead? Does anyone have any suggestions for a better temporary solution to the problem than gaffer tape?
I'd welcome any advice anone can offer Very Happy
rjdutch
hijet parts
Post by bones 851 on Thu Mar 10, 2011 10:05 pm
try giving hijet parts .co.uk an e-mail, good chap called sean may be able to help u out.....happy motoring bones851, their not just vans more like full time hobbies, but worth it,,,,,,,,, affraid
bones 851
Re: Broken clip on radiator cover
Post by rjdutch on Fri Mar 11, 2011 1:56 pm
Cheers for that, I'll give them a go. Temporarily, I'm using a bolt with a useful head size, a nut and a washer. This seems to be holding nicely and seems to be a bit of an improvement on gaffer tape! Hopefully I'll have the proper item on there soon.
Ta very much!
rjdutch
Post by PFM on Fri Mar 11, 2011 4:46 pm
