NOT FIRING ALL THE TIME ON NUMBER TWO CYLINDER
Post by thumper on Sun Oct 02, 2016 6:17 pm
GOT REALLY LOW ON GAS THE OTHER DAY, STARTED RUNNING ROUGH EVEN AFTER FUEL UP CHECKED IGNITION COIL ON PLUGS ALL WERE GOOD (OH YEAH SORRY I HAVE A 2000 HIJET VAN V210 S SO I STARTED PULLING OFF FUEL INJECTOR LEADS FOUND THE MIDDLE CYLINDER NOT RESPONDING BOUGHT SOME FUEL INJECTION CLEANER FROM CRC RAN ABOUT 80 MILES NOW HERES THE PROBLEM
--------STARTING OFF FULL POWER DEVELOPES AFTER SHUT DOWN AND RESTART SPIT SPIT SPIT RUNS ON TWO CYLINDERS ONCE AN A WHILE COMES AND GOES WITH POWER MAKES FULL POWER WHEN WORKING CORRECT BUT THEN CAN RUN ONLY ON TWO CYLINDERS FOR MANY MILES AGAIN ALWAYS STARTS AND RUNS FINE AFTER SETTING I'M BAFFLED ::: ???? ANY ONE CAN HELP OR HAS PROBLEM LIKE THIS I THOUGHT I MUST HAVE GOT TRASH IN MY INJECTOR BUT THEN IT RUNS FINE AND BACK TO CRAP ?:?
thumper
Re: NOT FIRING ALL THE TIME ON NUMBER TWO CYLINDER
Post by HighlyJetted on Mon Oct 03, 2016 8:22 am
It will either be a coil pack, plug or igniter problem.
Or you have a burnt exhaust valve.
