Coolant Temperature Sensor
Post by wrightgeordie on Sat Oct 15, 2016 9:09 pm
Can anyone help me with a coolant temperature sensor for a 2002 1.3 EFI Van. Plenty listed on ebay as the correct part but none are the 3pin type that I need to fix my van.
Last edited by wrightgeordie on Sat Oct 15, 2016 10:25 pm; edited 1 time in total (Reason for editing : grammer)
wrightgeordie
Re: Coolant Temperature Sensor
Post by Woodie on Sun Oct 16, 2016 10:03 am
There are two thread sizes too. The taller sensor is a large thread and may be Blue or Black ( can't remember the Across Flats measurements --may be 22mm) and a smaller threaded, shorter , black one. Can't be of much more help than that.
Post by wrightgeordie on Sun Oct 16, 2016 3:54 pm
Thanks for this Woodie. Having failed previously to locate the correct sensor I was told that a sensor from a Daihatsu Sirion would do the job. Getting a thread adaptor on ebay wasn't a problem and the new sensor fitted OK, this solved my engine management light problem but put the needle on my temperature gauge off the scale at normal operating temperature. They don't publish resistance values in the handbook so its back to trial an error I guess.
wrightgeordie
Post by Woodie on Mon Oct 17, 2016 9:02 am
That should have read Blue or Green Sensor. My brain hurts!!
