993 Radiator required
Post by large519 on Fri Mar 25, 2011 8:39 pm
In need of a rad for my 993, R reg??? If anyone can help be much appreciated.
large519
Re: 993 Radiator required
Post by rich the mechanic on Fri Mar 25, 2011 8:53 pm
I havn't got a spare but I have repaired mine whats up with yours?
Post by PFM on Sat Mar 26, 2011 1:55 pm
My local radiator company had one in stock - cost just under £100 on an exchange basis. I thought it was worth it for a completely refurbed unit.
Post by Blackaxe on Sat Apr 16, 2011 10:32 am
Hello. I have a rad for a 993. I bought it from a breakers less than six months ago it looks new. It is on my last Hijet which has expired and am breaking for spares. Interested?
Blackaxe
Post by large519 on Sun Apr 17, 2011 11:58 am
rich the mechanic wrote:I havn't got a spare but I have repaired mine whats up with yours?
Small stone chip i assume put a small hole in it just behind the bumper, a small jet of water squirts out once it gets hot. What did you use to repair it, I've so far used rad weld and ground black pepper, was thinking of trying jb weld, but any repair will be a short fix.
Blackaxe... Yeah I would be intersted, how much would you be looking for, inc postage??? or where do you leave if not too far could collect.
large519
Post by rich the mechanic on Mon Apr 18, 2011 7:09 pm
Mine had a hole in the back where it had split so I opened the hole up a touch with a small screw driver ground all the edges with a bit in the dremel and the soldered it with plumbing solder pinching it back shut after I had a little inside and run a bead up and down from it on the outside not pretty but can't be seen when fitted.
