Wheel stuck on!
Wheel stuck on!
Post by andy pyke on Wed Dec 28, 2016 10:27 pm
I would have posted this as a follow on to yesterdays discussion on tiny wheels. tires etc......except I can't find that string of posts!
Anyway, does anybody have any suggestions as to how I can get a wheel off that is stuck on? I've whacked it with a large hammer; not budging. Whack it harder?
andy pyke
Re: Wheel stuck on!
Post by GEORDIE on Wed Dec 28, 2016 11:33 pm
I had the same problem last year,got to gararge to shift
it,on a ramp,but a strong bit of wood across the rim clouting and turning the wheel abit after each couple of
wacks!! good luck
GEORDIE
Re: Wheel stuck on!
Post by Woodie on Thu Dec 29, 2016 12:23 am
I usually use a Sledge Hammer hitting the tyre on the inside of the wheel with the flat side of the head of the hammer turning the wheel a little bit each time. Always works for me.
Before putting a wheel on I always grease the stub of the disc and the centre hole of the wheel. If it is a steel wheel sandpaper the hole edges to get any rust off or if an Alloy same again to get the corrosion off before greasing it.
Re: Wheel stuck on!
Post by Logi on Thu Dec 29, 2016 7:43 am
As Woody says, if at first you don't succeed, use a bigger hammer Smile
DON'T hit the wheel.
Re: Wheel stuck on!
Post by andy pyke on Thu Dec 29, 2016 1:50 pm
I've just tried loosening off bolts and driving, hard breaking etc. No luck whatsoever. Have whacked it hard lots of times with a sledge hammer.
Logi, it's going to be your way next... BIGGER HAMMER!
Nothing's ever straightforward is it?!
andy pyke
Re: Wheel stuck on!
Post by Logi on Thu Dec 29, 2016 2:15 pm
If suspended securely I sometimes lie on my back and stamp alternate edges of the tyre, works for me Smile
Re: Wheel stuck on!
Post by HighlyJetted on Thu Dec 29, 2016 4:56 pm
I put big block of wood on the rim, then batter it with a lump hammer.
Re: Wheel stuck on!
Post by verryoldman on Thu Jan 12, 2017 10:17 pm
Had a customer bring a Cortina GT in, we tried to remove rear wheels as part of service no  luck block of wood, oil, heat, Bigger hammer, Sledge Hammer No more heat more hammer still no go had to cut them off in the end what had happened was BIG bloke + wheel nuts TIGHT, TIGHTER, Now check them again Suspect
The wheel centre return was acting like a huge spire clip never seen it before or after
verryoldman
Re: Wheel stuck on!
