Hello all!
Hello all!
Post by BamBam86 on Thu Dec 29, 2016 10:50 pm
Hi all I'm about to aquire a 1996 hijet pick up. I will be looking to build a drift truck with it. I was wondering if any one could advise the best place to buy some thinner seats I'm a big lad and could use abit more clearance. I was also wondering g if any one know where I can get a lowering kit?
About me I've been building g project cars since I was 7 currently I have a mk1 mx5 and a lexus ct200h both of which will be staying the mini truck is an inch I've had to scratch for a while. All my friends call my BamBam.
BamBam86
Re: Hello all!
Post by GEORDIE on Thu Dec 29, 2016 11:24 pm
welcome.good luck with the project
GEORDIE
Re: Hello all!
Post by Woodie on Fri Dec 30, 2016 12:50 am
Well hello BamBam. If you have have got a rather large BumBum and a body to match then an early Hi-Jet Pick up just isn't going to be any good to you. They weren't designed for us over size Brits, but rather for Dumpy little Italians or small Japs, not Sumo Wrestlers like yourself. Rolling Eyes
The Pickup seats are wafer thin anyway and if you are retaining a front engined,, in line configuration then you will need the folding forward backed seats for access to the engine bay underneath both seats. You haven't told us what engine and configuration you are intending to use. If you fit rigid seats then you will have to unbolt the seats just to check the oil level or top up the oil under the passenger seat.
For more leg and Bum room in the cab you will need a later Piaggio Porter with the extended cab. It's about 4" deeper rearwards and would probably be the answer to your need of more room.
I have a 58 plate rolling truck that was an Electric version Milk Float and was left hand drive so the driver could alight onto the pavement instead of getting flattened by an Artic, on exiting the offside door.
This could be the solution to your project.
Re: Hello all!
Post by Logi on Fri Dec 30, 2016 8:49 am
Welcome, as has been said, the pickup isn't exactly overendowed with room and the seat configuration is a problem, I've seen modded seats but nothing to give you any more space.
Re: Hello all!
Post by scotia on Fri Dec 30, 2016 10:22 am
welcome Smile
sounds nice, keep the updates comming.
Re: Hello all!
Post by andy pyke on Fri Dec 30, 2016 4:55 pm
velkum
andy pyke
Re: Hello all!
Post by Raggy on Fri Dec 30, 2016 6:46 pm
Keep us posted with progress, too many times people come on here with quite interesting projects...and last we hear of them! Remember keep coming back and post some pics.
Re: Hello all!
Post by HighlyJetted on Sun Jan 01, 2017 10:48 am
BamBam86 wrote:Hi all I'm about to aquire a 1996 hijet pick up. I will be looking to build a drift truck with it. I was wondering if any one could advise the best place to buy some thinner seats I'm a big lad and could use abit more clearance. I was also wondering g if any one know where I can get a lowering kit?
If you are a big guy, you should look at vans instead of pickups.
I have pick up (now with a welded diff and bike engine), but I felt my vans had better weight distribution for getting a slide on, and there is infinite more leg room in a panel van.
Got to love an MX5! Anyway, good luck.
Re: Hello all!
Post by Woodie on Wed Jan 11, 2017 10:13 pm
Hmmmm!! Looks like Bam-Bam has
Drift-Trucked Off !!! Sad Come on BB, have you bought the Pick up yet??
Re: Hello all!
