Porthole in sliding door
Post by elfin girl on Sat Jan 14, 2017 2:04 pm
Re: Porthole in sliding door
Post by Raggy on Sat Jan 14, 2017 3:47 pm
Isn't the sliding door just a single skin I.e 2-3mm?
Post by elfin girl on Sat Jan 14, 2017 4:58 pm
Raggy wrote:Isn't the sliding door just a single skin I.e 2-3mm?
I don't know! The middle bit is certainly thinner that the edges, but couldn't work out if it was two layers and whether there was any gap between them
Maybe I should just buy the window and cut a circle of ply for inside if it needs to be made thicker to fit it
Post by Logi on Sat Jan 14, 2017 6:11 pm
Yep, single skin.
Post by elfin girl on Sat Jan 14, 2017 8:55 pm
Ok, I th Nk I'll still buy it, I'm sure adding some ply will do the job, itle certainly reduce the cost of going through the toll going to Wales
Post by Logi on Sun Jan 15, 2017 8:46 am
elfin girl wrote:Ok, itle certainly reduce the cost of going through the toll going to Wales
They CHARGE you for going to Wales? I'd have thought that you paid to leave.... Wink
Post by bushwhacker on Fri Jan 20, 2017 4:48 pm
I wouldn't have thought that would do at all since it is supposed to be for a panel of nearly 1 inch thick which a Hijet door isn't. Would take quite a bit of plywood to bulk it out.
Post by elfin girl on Fri Jan 20, 2017 5:41 pm
bushwhacker wrote:I wouldn't have thought that would do at all since it is supposed to be for a panel of nearly 1 inch thick which a Hijet door isn't. Would take quite a bit of plywood to bulk it out.
I was thinking of getting some thinner ply and panelling the whole top section so I could put some insulation In between, seeing as that's the side I sleep on and the metal work can be a bit cold on my butt when I turn over in my sleep clown
