K Seal? Coolant? help me out where does this go!
Post by Fuzzydoguk on Tue Mar 29, 2011 5:38 pm
Hi all
right busy creating a to do list for the new van first things is dealing with the potential of overheating - drove it home for an hour and the guage never moved from half way so im relatively happy.
Just reading through the forums though and keep seeing mention of K seal where does this go?
Can you tell im not the most technical, Im planning on learning as I go with this project.
Cheers
James
Fuzzydoguk
Re: K Seal? Coolant? help me out where does this go!
Post by difflock123 on Tue Mar 29, 2011 5:47 pm
K seal is a liquid that you pour into the radiator/cooling system IF your vehicle is using water (either leaking radiator or head gasket)
if yours isnt overheating, there isnt much you can do to prevent it in the future (apart from service the vehicle well and make sure you use coolant)
Best of luck Smile
Post by Fuzzydoguk on Tue Mar 29, 2011 6:44 pm
Ok thanks, what should I put in the Coolant reservoir under the seat? should it be water or coolant and if so what coolant is good to go with?
James
Fuzzydoguk
Post by difflock123 on Tue Mar 29, 2011 7:11 pm
engine coolant should be a mix of 50% water (distilled/deionised but most use tap water) and 50% antifreeze/summer coolant.
I normally get mine from halfords as its quite often on offer (last time I got mine, if you bought 5L of engine oil, you got a 5L tub of premixed coolant mixture Very Happy )
I actually think the premixed coolant is a better option for most people, as theres no worrying about correct mixtures
have you downloaded the manual appropriate for your hijet from this forum yet?
I would strongly recommend you do Smile
Good luck, and hope that helps.
Post by Fuzzydoguk on Tue Mar 29, 2011 10:03 pm
Brilliant thanks for that will go get some tomorrow one more stupid question (for tonight Laughing ) the coolant bottle is full of water how do I drain it to fill with errrr coolant Very Happy
Fuzzydoguk
Post by rich the mechanic on Tue Mar 29, 2011 10:26 pm
there is no drain so you can either suck it out with something or syphon it although i would not want a mouthful of that water other option is a pump
Post by PFM on Wed Mar 30, 2011 8:27 am
Fuzzydoguk wrote:Brilliant thanks for that will go get some tomorrow one more stupid question (for tonight Laughing ) the coolant bottle is full of water how do I drain it to fill with errrr coolant Very Happy
It's only held on by 2 small bolts - take it off and let the missus give it a splash in the bowl at the end of her washing up.
