lspv brake valve
lspv brake valve
Post by busjet on Thu Jan 19, 2017 2:46 pm
hello all. i need a brake compensator valve to pass my MPV's MOT, can any one help? thanks.
busjet
Re: lspv brake valve
Post by sputnik on Thu Jan 19, 2017 3:22 pm
Can't help you out with an LSPV but this thread might be of interest?
http://hijet.findtalk.biz/t1822-lspv-rear-brake-woes-mot-failure-game?highlight=lspv
sputnik
Post by busjet on Thu Jan 19, 2017 3:55 pm
thank you for the thread, its very helpful . this is ok if the valve is not seized, according to a breaker supplier i spoke to yesterday many vans that he received had the compensator valve replaced by a T peace and they worked fine and must have passe their MOT.
busjet
Post by HighlyJetted on Thu Jan 19, 2017 11:02 pm
T piece should be an MOT failure.
Method of InspectionE. Valves
1. Check for excessive discharge of oil from valves.
2. Check that a load sensing valve is present and connected, if it is a standard item.
3. Check the condition and operation of the load sensing valve where fitted, including any operating linkage.
Reason for Rejection
1. Excessive discharge of oil from a valve.
2. Evidence that a load sensing valve has been removed or disconnected from a vehicle where it is known to have been fitted as standard.
3. A load sensing valve or its operating linkage obviously:
seized or inoperative
defective so that its function is impaired, or
incorrectly adjusted.
lspv brake valve
Post by busjet on Fri Jan 20, 2017 8:42 pm
thanks highly jetted, now i have to find a replacement valve pretty soon.
busjet
