shonky diy replacement sliding door handles.. they work great!
Post by danielfrisbee on Fri Jan 27, 2017 9:13 pm
So, many months ago the door handles on the sliding doors came off in my hands, in pieces admittedly, there was a period where bits still hung off, but in the end they were gone. An mot failure I discovered, as I have the mpv with seats. One solution, is to take all the seats out for the mot, but I had always intended to resolve the issue and this forced my hand.
Buoyed by the success of my shonky diy roofrack, I turned my very amateur metalworking skills to making some door handles from some rusty steel I had left over from another project.
Having now done it I can see how to do it better next time, though there won't likely be a next time, as these handles are so solid they will outlive the van. They currently don't lock, though I've come up with a relatively easy modification (with magnets!) that will get them locking.
So, if anyone else out there has lost hope faffing around with door handles, if you can be bothered, there are solutions. It's so nice being able to open and close the doors as hard as I like, and as having sliding doors is still a novelty for me, every slide and clunk is very satisfying..!
danielfrisbee
Re: shonky diy replacement sliding door handles.. they work great!
Post by danielfrisbee on Wed Feb 01, 2017 1:43 pm
still waiting for applause for these...! though I've realised a slight design flaw, which is that the way I've done them means the windows now only wind down half way. Not the end of the world, silly of me to think I could get it right first time-
danielfrisbee
Post by Woodie on Wed Feb 01, 2017 5:13 pm
You mean that your windows actually. wind up and down? You are a lucky man. Only ever found 4 winders that worked properly. Even then they needed a bit of help pulling the glass back up and had been given copious amounts of. oil in the coiled spring and bristle materials they put in the middle of the spring.
Post by Raggy on Wed Feb 01, 2017 8:20 pm
Well done that man! A good solution and neatly done.
Post by danielfrisbee on Wed Feb 01, 2017 8:59 pm
thankyou for the solicited kindness..! Read through your skylark posts earlier for inspiration raggy as I've been thinking about maybe fixing up the van a bit more now that it's passed its mot. Yes woodie both windows went all the way down, which impressed and surprised me. However the theoretical moment of lying in a bed in it and winding the window down to catch the warm morning sea breeze is sufficiently unlikely that a 50% opening window will have to do.
danielfrisbee
Post by Woodie on Wed Feb 01, 2017 9:08 pm
When we first chatted Dan you said that you were very inventive. Well you have certainly proved that point son.
Well done. You have achieved something else that I have never got round to.
And sorted out your headlights and got the van through the Mot.
So for someone who told me that he had no mechanical skills you should be very proud of yourself. And next time - - tell the truth.
Post by danielfrisbee on Fri Feb 03, 2017 12:41 pm
you're too kind woodie, i'm blushing-
danielfrisbee
Post by Logi on Fri Feb 03, 2017 6:22 pm
They're mans handles for sure Smile
Post by dennispenis on Fri Feb 03, 2017 7:54 pm
Nice, nothing like a bit of angle iron the ladies go mad for it
dennispenis
