Hijet Devon pop top camper .
Post by Barry 6448 on Fri Jan 27, 2017 10:32 pm
Hello to you all !
I've just bought a W reg Devon pop top Hijet camper with a broken engine . The previous owner said that it conked out and the AA man diagnosed that the cam shaft had snapped . So I'm looking for a good running engine ? Thank you in advance Barry
Barry 6448
Re: Hijet Devon pop top camper .
Post by Woodie on Fri Jan 27, 2017 10:56 pm
You don't mention where you live Barry. It is helpful if members give even just the nearest big town. You don't have to post your address ( dangerous thing to do - Logi might arrange for a Call girl to turn up on your doorstep) Twisted Evil
I have an X reg Pickup that I might be persuaded to break up so long as you aren't in a desperate hurry. Health issues are making it difficult to get major jobs done but slowly on the mend.
My email address is : thehijetmaniow@gmail.com
Post by Barry 6448 on Fri Jan 27, 2017 11:33 pm
Hello sorry I thought I'd posted where I live I'm down in Somerset .
I would be interested in your pick up engine . Also please could you tell me if all the 1300 engines are the same thanks Barry
Barry 6448
Post by Woodie on Sat Jan 28, 2017 12:11 am
There are minor differences on the 1300 engines. Early engines were two coil pack wasted spark ignition systems whereas later ones -  I think 2002 on were  four coil packs. Simple enough to sort by changing the Camshaft Cover over and ditching two of the coil packs and leads.
The X reg one I have is only 2 pack the  same as yours. There are even more differences the later the year of manufacture you get, such as the inlet manifold.
If you want to go for a good bit of more power and speed  then I have a 1600cc engine available, which has 30bhp more than a 1300. but that would require a good bit of work  swopping sump, manifolds, camcover and a few other bits and pieces over.  But a sedate  85 mph should be OK for what you need. I  guess.
Post by Barry 6448 on Sat Jan 28, 2017 12:16 am
Ok thanks for the info ! I was hoping just for a simple engine swap the 1300 is fine for me ! If you could let me know where you are and how much you are wanting for the engine that would be great thanks Barry
Barry 6448
