Speed sensor issue - Hijet randomly slowing down
Post by HarryWhite on Mon Apr 24, 2017 7:01 pm
Hi jeters
I'm new to the forum and was wondering if anyone had any advice.
I recently bought a 2002 Hijet van and I intend to turn it into a camper. The engine warning light has come on and it's apparently due to the speed sensor. He previous owner mentioned there was an issue with this and that it sometimes drops speed when up around 60 mph. This has happened to me while on the motor way and it was a bit more dramatic than the previous owner made out. The speed dropped to 40 mph before kicking back in! I've taken it into a Daihatsu garage who confirmed the warning light is due to the speed sensor but they didn't sound to sure of why it was slowing down. They said to replace the speed sensor would mean replacing the whole dash unit for over £300. I'm a little dubious as they didn't sound as though they knew why it was slowing down and I'd rather not lay out 300 quid. I was wondering if anyone has experienced this issue and had any recommended fixes??
Harry
HarryWhite
Re: Speed sensor issue - Hijet randomly slowing down
Post by Raggy on Mon Apr 24, 2017 8:10 pm
Don't spend that £300! If you search on here you will find others have had the same issue. The issue is the sensor and its part of the instrument unit which is dead easy to replace. Secondhand ones are available from eBay and other sources for much less i.e. £20 to £50 on average. I presume being an 02 its a 1.3. The reduction of speed to 40mph is what happens as the Control unit is not getting the correct data.
Try this at only £10
Post by HarryWhite on Mon Apr 24, 2017 10:08 pm
REALLY appreciate the advice Raggy!!!! Got myself a fun job for the weekend and saved 290 pounds!
HarryWhite
Post by Raggy on Mon Apr 24, 2017 10:24 pm
and if it does not fix it you only lost £10 not £300!
Post by scotia on Tue Apr 25, 2017 8:56 am
i had the same problem but it was the speedocable that had broke on mine.
chances are big its the sensor like raggy said but if that doesnt fix it check your cable
Post by Woodie on Tue Apr 25, 2017 6:56 pm
Ullo 'Arry. Welcome to the the Machine. If by the sounds of your post, your speedo is registering your forward momentum then obviously the cable is ok.
Definitely the speed sensor. Easiest way is to fit another Instrument Cluster. I have some in stock so if you haven't found one yet, send me an Email to : thehijetmaniow@gmail.com and send your mobile number and I will give you a call. Woody.
Post by Woodie on Tue Apr 25, 2017 7:10 pm
Basically the speed sensor sends a message to the ECU. If that message is not being sent, the ECU thinks that the engine is in tickover mode and cuts the fuel. After a few minutes it resets and away you go again. If you keep your speed around 40 you can usually get by ok without it cutting out until you can put another Instrument Cluster in or change the Speedo Head.
Post by Gc24265 on Fri Sep 22, 2017 5:12 pm
Hi guys new to this forum I have had problems with my daihatsu hijet camper got all brake pipes replaced about 6 weeks age while they were doing the work they damage the speedo cable resulting in me having to replace it once I got the van back the first time I took it out engine management light came on and engine lost all power 5 mins later van was driving fine turns out the speed sensor was the fault it was reset
Gc24265
Post by Woodie on Fri Sep 22, 2017 5:21 pm
Hi GC. I have just replied to your email. It is a known problem with Hi-Jets. I had to drive one back to the Island from Berwick on Tweed. It stopped 22 times on the way back home. I then sussed that if I kept the speed at 40mph it would behave itself. Nightmare journey.
Anyway, yes I have got Speedo clusters in stock. Could send it tomorrow morning if you are happy with the quote I have sent you.
Post by Gc24265 on Fri Sep 22, 2017 5:37 pm
Hi Woodie
Yes I would like one of your speedometers do you have other parts.
Gc24265
Post by Woodie on Fri Sep 22, 2017 5:41 pm
Yes got a reasonable amount of varied spares. Email me your requirements or your phone number and I will contact you either way. thehijetmaniow@gmail.com
Post by Gc24265 on Fri Sep 22, 2017 5:43 pm
07557281802
Gc24265
Post by Woodie on Fri Sep 22, 2017 5:53 pm
Right thank you. I will contact you a bit later on.
Woody save the day
Post by Gc24265 on Thu Oct 12, 2017 3:28 pm
Gc24265 wrote:Hi Woodie
Hi Woody firstly thank you for saving the day with the speedometer Very Happy and also the fantastic set of headlamps they are is good as new the most important thing is you did this without robbing me as most dealers for Daihatsu hijets do and I have been stung in the past.
I will get some photos on the forum ASAP once I discover how to down load them onto the Forum.
cheers mate it has been a pleasure doing business with you.
cheers
bert Very Happy
Gc24265
Post by HighlyJetted on Fri Oct 20, 2017 10:50 pm
This old chestnut strikes again!
