Paint Code
Paint Code
Post by Moley_t on Mon May 22, 2017 9:54 pm
Hi guys, I have a 1999 1.3 efi and need some matching paint, it's dark blue. I found the code A01 and had it made up but it's far too light. Any ideas?
Moley_t
Re: Paint Code
Post by Logi on Mon May 22, 2017 10:39 pm
Go to a better paint supplier?
Hello Smile
Re: Paint Code
Post by Moley_t on Mon May 22, 2017 10:45 pm
He he. Don't think that's the problem, think the code is wrong, didn't know if anybody might have the "correct' one?
Moley_t
Re: Paint Code
Post by Logi on Tue May 23, 2017 6:06 am
Never heard of the code being wrong? Was it Halfrauds by any chance?
Re: Paint Code
Post by Woodie on Tue May 23, 2017 9:38 am
Sounds like you need to find a supplier with a Paint Spectrum Analyser to match your needs.
Re: Paint Code
Post by biofos on Thu May 25, 2017 1:14 am
If it's dark blue, non-metallic, it is likely to be Daihatsu River Blue Code B33. If it's metallic apparently there's lots of different blue's.
BTW, I've had cans of B33 mixed by Halfords. I found it an excellent match and it's superior to most other rattle-cans I've used. The spray nozzle is adjustable for pattern, vertical or horizontal and Halfords seem to pressurise the can higher than off the shelf cans. Be aware Halfords is stopping in-store mixing in the next 4-6 months. Instead you will be able to order direct from the manufacturer on the Internet and pick it up from Halfords next day. (Apparently it takes too long to mix paint in-store to make it viable).
biofos
http://www.biofos.com
Re: Paint Code
Post by Moley_t on Thu May 25, 2017 8:08 am
Thanks Logi and Biofos. It was Halfords. Mine's a metallic dark blue. Tried AO1 and B33 but not correct, anyone else have any other codes I could try?
Moley_t
Alternator rectifier
Post by Moley_t on Thu May 25, 2017 8:23 am
Hi team, with my limited knowledge I'm pretty sure the diodes have gone in my alternator. It's throwing out over 14v but I'm also getting an a.c. reading at the battery, which is also draining quickly. Trying to keep costs down so does any one know a supplier for the rectifier pack? Cheers.
Moley_t
Re: Paint Code
Post by Raggy on Thu May 25, 2017 7:46 pm
Much better if you start a new thread for this
Re: Paint Code
Post by Logi on Thu May 25, 2017 8:37 pm
Moley_t wrote:Thanks Logi and Biofos. It was Halfords. Mine's a metallic dark blue. Tried AO1 and B33 but not correct, anyone else have any other codes I could try?
They couldn't mix a dance track, go to a real paint supplier Very Happy
Re: Paint Code
Post by HighlyJetted on Fri May 26, 2017 1:42 pm
I found about about 6 different blue paint codes for Hijet.
Its a bit of a mine field.
Re: Paint Code
Post by Moley_t on Fri May 26, 2017 10:03 pm
Highly needed, what codes do you have?
Moley_t
Re: Paint Code
Post by HighlyJetted on Fri Jun 02, 2017 11:21 am
Non anymore, I needed paint for a blue one a few years ago.
Friendly with the local paint place, spent an hour digging though various paint catalogue comparing the colour swab samples.
Turned out to be a bit of an interesting guessing game.
Re: Paint Code
Post by Woodie on Fri Jun 02, 2017 2:46 pm
I had a repair done on my MPV and I went into Newport with Roy who does any paint jobs for me and the best match the paint supplier found for mine, was a Skoda colour.
Re: Paint Code
