Replacement door locks?
Post by Fuzzydoguk on Sat Apr 09, 2011 8:44 am
Hi all
Just discovered after finally getting hand brake fixed and back on the road, that the passenger side lock is faulty. It looks like a key has broken off in the barrel and I can open the lock with the tip of any key - not ideal!
Before I buy the wrong thing or spend too much has anyone got any tips or links to suitable, easy to replace door locks?
Many thanks
James
Oh and I'm blogging my experience converting my hijet (George) to a micro camper will post link when I have a bit more on there
Fuzzydoguk
Re: Replacement door locks?
Post by rich the mechanic on Mon Apr 11, 2011 8:20 pm
Hi try taking the barrel out and see if there is a hole in the back if not then try drilling one you maybe able to push the broken bit out.
Post by leopard_pagan on Wed Apr 13, 2011 9:07 pm
i had the exact same thing with the drivers door barrel & i'd make out i was using the key to unlock it!! didnt want anyone to know all you need is a screwdriver!
you can remove the barrel (inside door panel off) and with thin long nose pliers get the broken bit out.. you can also use a thin wire/paper clip to push the end of the key through to expose it to pliers...
only one downfall after i fitted the barrel back in to door...
i can use key to unlock it, but the key does not lock it.. have to push button down and hold door handle up when shutting it...
Post by PFM on Thu Apr 14, 2011 7:31 pm
leopard_pagan wrote:have to push button down and hold door handle up when shutting it...
I always do that - saves on lock and key wear. Can lead to lock-outs though - I now keep spare keys for my vans on my other key-ring (always in my pocket) as it's sometimes hard to find XXXXXXXXXXX to aid getting in.
Post by leopard_pagan on Fri Apr 15, 2011 7:35 pm
spare keys in my wallet, on my desk at home and set in the vans paperwork!
Post by rich the mechanic on Sat Apr 16, 2011 10:00 pm
I always have a back up plan as I have left keys in the ignition so many times its unreal that the first mod to our van was a back up way in and was so bad in the car with me leaving the lights on as well the car system has a seperate battery back up as well.
Post by Fuzzydoguk on Tue Apr 19, 2011 8:56 am
Ok so my grand plan yesterday was to fix the slide doors (done) start carpeting Walls (done) and take the door lock out to get it fixed -not done
How do I get it out anyone help? I took the door card off (though struggled there as I think the winder is superglued in the front) but could just see metal bits n bobs what am I aiming for?
James
Fuzzydoguk
Post by rich the mechanic on Wed Apr 20, 2011 9:25 pm
I think its held in with the fairly standard fashion of a spring U clip so feel around and you should find a right angled tab which you pull away from the lock then you maybe able to get a bit more room to remove the linkage clip which clips round the wire linkage and then the wire pulls out if the barrel tab.
