I need a hand with removing a split pin...
Post by Lex_Michdebus on Tue Jun 20, 2017 10:29 pm
I have this badly rusted split pin I can't seem to get out of the tie rod end thingie. I'm now at a point where I don't have any more split pin to grab to get it out... Is there a miracle worker in the house that can tell me how the flying f- these should be removed without that damn hassle every time? I'm going to grab the drill bits again (and they always break once or twice...), but next time I want to be able to remove the darn thing without having a stroke.
Who's with me?
Lex_Michdebus
https://youtu.be/zAH2jjzAhU8
Re: I need a hand with removing a split pin...
Post by Raggy on Fri Jun 23, 2017 12:09 pm
Anti seizure Grease? copper slip?
Post by Lex_Michdebus on Fri Jun 23, 2017 10:01 pm
Well... the new pins will get a nice coating of copper grease, but first I need to get the old ones out...
Lex_Michdebus
Post by Raggy on Fri Jun 23, 2017 10:17 pm
Drill
Post by PFM on Fri Jun 23, 2017 11:46 pm
Plus gas and/or heat.
Post by Lex_Michdebus on Sat Jun 24, 2017 1:32 am
Now I really hate split pins...
Lex_Michdebus
Post by Woodie on Sat Jun 24, 2017 7:51 am
Well I if you hate them that much, get your own back and take an angle grinder to the nut and cut it off and buy a new Track rod end that has a Nylock nut on it and you won't have to use a split pin. lol!
Post by 602 on Sun Aug 20, 2017 9:10 am
Hi,
Many a time I have jus grunted loudly, turned the nut which sheared of the head and tails of the split pin, and just carried on unscrewing the nut. This sometimes ruins both the nut and the male thread, not a problem if you are going to replace both anyway.
Unless safety, and the MOT tester, decree otherwise, don't use split pins. Instead, search EBAY for "R-clips".
Of course, if you peen the end of the thread over, you won't need either. I'll get my coat.
602
602
Post by verryoldman on Sun Aug 20, 2017 10:45 pm
Bow tie locking pins one type
locking pins another
google Images for aircraft safety pins
verryoldman
Post by Woodie on Mon Aug 21, 2017 8:35 am
Another method I have used if you can't get access with a drill or just can't finish the job because a bit of the drill has snapped off is to dot punch hard between the castellations on the top of the thread - assuming that you have got access enough for a decent hammer.
Post by Logi on Tue Aug 22, 2017 8:52 pm
Or just weld the fucker on Twisted Evil
Post by Lex_Michdebus on Thu Aug 24, 2017 8:42 am
The Micra needs a new driveshaft. I am still procrastinating this job because I need a complete free weekend to get it done, just because of this devil split pin...
Lex_Michdebus
