romahome front jack legs
Post by wee phil on Wed Jun 28, 2017 11:44 pm
hi looking for the front support jack legs for a romahome
wee phil
Re: romahome front jack legs
Post by Woodie on Wed Jul 05, 2017 6:26 pm
Found you some Jacks Phil Boyo if you are still needing a set. If not then Ebay tomorrow.
Post by wee phil on Wed Jul 05, 2017 7:01 pm
yes woodie defo need front ones how much
wee phil
legs
Post by wee phil on Wed Jul 05, 2017 7:03 pm
Woodie wrote:Found you some Jacks  Phil Boyo if you are still needing a set. If not then Ebay tomorrow.
yes woodie defo much are they its front ones for taking body of
wee phil
Post by Woodie on Wed Jul 05, 2017 7:11 pm
Yes Phil they are  for the front. You have to use the rear Corner steady Jacks at the rear. Did the Suzuki have the rear Corner steadies on it. From the picture I saw of it it didn't look as though it did.
If you bought that Suzuki then you will have to use a 3" block of wood  under each jack to lift it up as Romahome bodies don't fit on the later model Suzuki as the cab is higher and the body has to be lifted up on the rear bed by about 2" I think from memory.
Post by wee phil on Wed Jul 05, 2017 7:16 pm
no its mounted on a rascal pickup
wee phil
Post by wee phil on Wed Jul 05, 2017 7:17 pm
and sorry yes its got back ones one it
wee phil
Post by Woodie on Wed Jul 05, 2017 7:18 pm
Is it a 1300 model or 993cc.
Post by Woodie on Wed Jul 05, 2017 7:19 pm
Post by wee phil on Wed Jul 05, 2017 7:22 pm
970 with suzuki in it was looking for a 13 engine if i can get one to fit
wee phil
Post by wee phil on Wed Jul 05, 2017 7:28 pm
or a suzuki carry pickup or daihatsu one 1300cc would buy
wee phil
Post by Woodie on Wed Jul 05, 2017 7:30 pm
The later model has a higher cab and the Romahome body has to be lifted up on a wooden framework by two or 3 inches I seem to remember. May be wrong. Its some years since I was doing Romahomes full time. That and Senile Dementia. Right time for food. Signing out for tonight.
Post by wee phil on Wed Jul 05, 2017 7:32 pm
much is legs
wee phil
Post by wee phil on Wed Jul 05, 2017 7:33 pm
if it helps the model has in board water tank
wee phil
