Side door bearings
Side door bearings
Post by MATTT on Sun Jul 02, 2017 7:17 pm
Had a look at some old threads,the links dont seem to work for the fitting guide threads for some reason
Anyhow read on here the bearings were 688ZZ,so ordered some of those .
Had a quick look this afternoon, the lower front bearing is bigger,does anyone have the type?,if im doing it ,i was going to change all of them together
Also took the top bearing arm out to have a look ,and the bearing has a flat pin holding it in place ,no screw or torx slot to remove it,how do they come apart,didnt want to start on it and end up with the door off in the street !
Cheers
Matt
MATTT
Re: Side door bearings
Post by Woodie on Mon Jul 03, 2017 8:22 am
You should always check with Woody first. I keep new bearings in stock and have loads of used bottom bearing. Top bearing arms are rather thin on the ground though.
I have recently got in stock Track Rod End Dust Covers and Track Control Arm Ball Joint Dust Covers too. ( end of the lower arm where it fits into the McPherson Strut.)
It is always worth dropping me an email first as I may have what you are looking for: thehijetmaniow@gmail.com
Post by MATTT on Mon Jul 03, 2017 11:30 am
will do , i will email you now
thanks
Matt
MATTT
