Removing the door handle and winder
Post by Fuzzydoguk on Sat Apr 09, 2011 6:10 pm
Hi all
Fun few hours stripping the interior of the van for project camper, surprised at the space!
One question how the fek do you get the handles off to remove the door panel, in the manual it says use a cloth and turn but I'm stumped
Anyone?
James
Fuzzydoguk
Re: Removing the door handle and winder
Post by leopard_pagan on Sat Apr 09, 2011 7:09 pm
they are held on with clips, you need to push the door card back enough to see and get pliers in to grab the clip.
unless there is another way that i have yet to know,.... this is how i did mine.
Post by Fuzzydoguk on Sun Apr 10, 2011 9:04 pm
Ah ha thanks got them off with a mix of screwdriver wiggling and brute force, found out my window winder was superglued in place though!
Fuzzydoguk
drastic measures
Post by bluevandriver on Tue Jul 12, 2011 9:48 pm
Having broken the thin plastic edge where clip is this time I used a sharp stanley knife to cut trim in a straight line below winder. Cut does not look to bad and made window repair easy
bluevandriver
