Mot failures
Mot failures
Post by Brainsparks30 on Mon Apr 11, 2011 6:37 pm
Just drove back from yorkshire in my 'new' 1997 1.0 hijet mpv. Not driven for some time when I collected. No obvious problems, but back in norfolk mot man says that the emmisions are high/fail and the rear brakes have no effort. I am thinking that a service would help, and I heard something about spraying WD40 onto the compensator valve? Does any one have any greater ideas?
Brainsparks30
Brake
Post by d1noh on Mon Apr 11, 2011 8:32 pm
it will help a little but take the linkage off and free it up, no need to undo the brake pipes
Re: Mot failures
Post by leopard_pagan on Wed Apr 13, 2011 9:09 pm
where in Norfolk are you?
i'm in Suffolk/Newmarket and my MOT guy knows my van :0)
kenford Commercials
Post by Brainsparks30 on Thu Apr 14, 2011 3:36 pm
I am near Thetford (gladly not in it). I have some days left for a partial retest. It might be worth the trip next time round for full mot if they have better understanding.
Also, I noticed that my cat conv body is loose on its pipes so it can be rotated and slid to and fro, which is...weird. Like it has no welds on it. I am shure it is not gas tight. I am suspecting that this is could be to blame for the emmisions being high?
Brainsparks30
Brake
Post by Brainsparks30 on Thu Apr 14, 2011 8:45 pm
d1noh wrote:it will help a little but take the linkage off and free it up, no need to undo the brake pipes
The linkage seems to be moving ok now but I am now thinking about how the valve inside might be siezed. Not shure what the normal unloaded position should be. The spring looks worn and weak strength. Is it possible to take valve apart to flush out any muck?
Brainsparks30
Re: Mot failures
Post by leopard_pagan on Fri Apr 15, 2011 7:37 pm
lol at "near" thetty... Suspect
Re: Mot failures
Post by 8bit-ash on Sat Apr 16, 2011 12:21 pm
I've just had a complete pig of a job getting my van through the MOT due to no rear brakes. First off i'd whip the rear drums off and have a look. Chances are your wheel cylinders are seized. If you need some this was the cheapest place I found -
http://www.motaparts.com/cgi-bin/Motaparts/motaquip.asp?Page=2
Mine also needed the compensator valve sorting.
ps i'm in Norwich so not far away
Wheel cylinders
Post by Brainsparks30 on Tue Apr 19, 2011 11:18 pm
Thanks for the link, prices have varied wildly elsewhere but none were exactly cheap!
Brainsparks30
Re: Mot failures
