Spot lights etc
Spot lights etc
Post by Raggy on Thu Jul 27, 2017 10:56 pm
With my new front end for Skylark I am putting on angel eye daytime lights with combined fog lights, which I will wire into the existing fog light switch etc but with the new bull bar I will be adding two new spots/driving lights on a separate switch. Anyone show me a diagram how and advice on wiring them in? Electrics were never my strong point but willing to learn. Already got an illuminated switch for them, presume I need a relay but just need a pointer with where to supply it from etc.
Re: Spot lights etc
Post by Woodie on Thu Jul 27, 2017 11:02 pm
Not sure if it is still the law these days Raggy but it used to be that the Spotlights should only come on with main beam and extinguish on Dip.
I will gladly talk to you about the wiring in bit my friend.
Re: Spot lights etc
Post by Raggy on Fri Jul 28, 2017 7:31 am
Could be right there, its been a while since I put them on my mini, remember wiring them to a switch but could have been the fog I had to a separate switch, memory fails me! (Which is getting more regular!)
Re: Spot lights etc
Post by Raggy on Fri Jul 28, 2017 12:50 pm
Getting more complicated than I thought, just reading that:
1) Daytime running lights should come on automatically when the engine is started, and which turn off automatically when headlights or sidelights are lit. Presume I can sort this with a relay.
2) Driving lights should be wired to engage only when the high beams are in use. Fair enough, suppose I can pick off a feed from the column light switch. What about having an override switch in case I want them on say when camping to set up.
Am I best running a new feed from the battery for these lights or is there a closer point to take a feed from?
No wonder I left this bit to the end of the mods I'm doing  Laughing
Re: Spot lights etc
