Distributor Question
Post by Westy1 on Wed Aug 30, 2017 10:37 pm
Hi people been following the group for a while but this is first time for posting hope I don’t make mess of it. I have a question about the Distributor on my Camper.
1999 Hijet 993 EFI petrol engine, had to get under a few days ago to check exhaust and found rubber pipe about 30cm long just hanging down from the body of the Distributor open end has a clip on suggesting it should be attached to something.
Engine is running fine been over to the Lake District a few times and North York Moors recently (I live in the Teesside area of the UK so decent mileage.)
Anybody any ideas please going to attempt to put a picture up.Thanks,  hope the link works   Sorry can't get photo up try again
http://illiweb.com/fa/pbucket.gif?sort=3&o=0
Westy1
Re: Distributor Question
Post by Woodie on Thu Aug 31, 2017 5:21 am
Westy 1? Hope you are not going to turn out to be a little Terrier. The moulded pipe you have found is there to let out any moisture that forms in the Distributor when the engine cools down and as a breather.
So panic ye not. It is supposed to be like that. If you look closely you will see that the end of the rubber moulding is blocked and there is a small square hole in the side of the moulding - unless some twerp has cut the bottom of the pipe off.
Post by Westy1 on Thu Aug 31, 2017 11:58 am
Morning, thanks Woodie at 5ft 4" I am little and been called worse than a terrier HaHa.
But that is not the pipe I was meaning I sussed that one, The pipe I'm looking at is on the metal body of Distributor as it goes into engine block not the cap.thanks again I need to get uploading photos sorted. https://ibb.co/fb2jj5
Westy1
Post by scotia on Fri Sep 01, 2017 8:55 am
Post by scotia on Fri Sep 01, 2017 8:57 am
you need to post the BBCode not the direct link
when you view a picture there are a couple of codes you can copy on the bottom of the page.
copy the BBCode one for full image (not thumbnail)  and paste it here
thats the way i post pictures from my oldskool pc, it could be different when using tablet or phone Neutral
Post by Woodie on Fri Sep 01, 2017 9:06 am
From Scotia's picture and mine It appears to be a breather pipe once again. The metal pipe is not connected to anything in the Distributor as in a mechanical advance /retard mechanism as most distributors had years ago.
Post by Woodie on Fri Sep 01, 2017 9:11 am
Yes, it is FAR easier using a Tablet Scotia. Even I can do it. Haven't got a clue what you were describing and I wonder if Westy would either. Posting pictures on my Laptop was dreadful hit and miss experience. Utterly archaic system.
Post by Westy1 on Fri Sep 01, 2017 11:15 am
Thanks for your help Woodie & scotia I'l leave well alone then if it's not broke don't try and mend it.
Will give the BB code a go later thanks again catch you later.
Westy1
Post by scotia on Sat Sep 02, 2017 11:23 am
scotia wrote:you need to post the BBCode not the direct link
Woodie wrote:Yes,  it is FAR easier using a Tablet Scotia. Even I can do it. Haven't got a clue what you were describing and I wonder if Westy would either.    Posting pictures on my Laptop was dreadful hit and miss experience. Utterly archaic system.
thats because i was talking about the website (https://ibb.co/fb2jj5) westy uses.. not the website (servimg) like you do woodie.
first i clicked on the link
then click on this
than copy bbcode and paste the link on the forum
like i said it could look different when using phone or tablet.
i cant help you if you do..
but when using a pc like me i dont know how somebody wouldnt understand my explanation.. Neutral
Post by Woodie on Sat Sep 02, 2017 12:49 pm
It's just this Old Fossil then obviously Scotia with a wierd blend of old and new technology. Seems like Westy although 15 years older than me does undoubtedly understand. But I have never owned a tower computer and separate keyboard so can I please be excused?
I just know that it was a real pain with my Sony Laptop to try and post ANY pictures.
Post by scotia on Sun Sep 03, 2017 11:06 am
yeah i dont know why they just couldnt make one layout or one simple way of posting pictures.
its difficult, and especialy when using different divices and trying to explain to somebody who uses a different device.
Post by Westy1 on Mon Sep 04, 2017 10:45 am
Found the BB code Scotia, what image hosting site do use ? might be easier if I use same as other members.
Westy1
Post by scotia on Mon Sep 04, 2017 4:10 pm
if you copy that code and post it here the picture will be visible no?
i use Servimg.com and woodie to but if the one you use now works, why change?
