Oil leak rocker cover.
Post by Ben Lee on Tue Sep 12, 2017 5:29 pm
My newly bought Piaggio Porter (2003) has an oil leak, it seems to be originating from the valve cover (don't really know de English term) from the engine.
Known problem? Known solution?
Thx.
Ben Lee
Re: Oil leak rocker cover.
Post by Ben Lee on Tue Sep 12, 2017 9:37 pm
Ben Lee wrote:My newly bought Piaggio Porter (2003) has an oil leak, it seems to be originating from the valve cover (don't really know de English term)
Found the proper English word... The rocker cover...
Today I put the Piaggio inside our garage (the new Korando can sleep outside) an after a drive it seemed tot leak just a drop shortly after parking it.
I put a cardboard under it, but 10 hrs later, not an extra drop..
Grz,
Ben
Ben Lee
Post by scotia on Wed Sep 13, 2017 10:20 am
it could be because metal shrinks and expands when hot or cold, that could be the reason why it only leaks when hot.
clean it good and watch were its comming from.
you could replace the kleppendekselpakking/rockercovergasket if its no good
Post by Ben Lee on Wed Sep 13, 2017 11:46 am
Thx... First I will have to clean the engine to see where the leak originates.
Think I have two, today I had two drops in different places (in 36 hrs more or less)
Ben Lee
Post by scotia on Wed Sep 13, 2017 12:59 pm
the gasket only costs around 15 euros or so, so the damage wont be that bad
i think this is it 11213-87103 PIAGGIO
Post by Ben Lee on Wed Sep 13, 2017 2:32 pm
Thx.
Ben Lee
