Windscreen wiper wipe out
Post by al kaline on Thu Nov 16, 2017 6:35 pm
Driving the new Hijet and there seemed to be a split second numbing of power (headlights dimming) and the windscreen wipers cut out and won't work.
Luckily it the time i was approaching the driveway and not on the motorway in heavy rain or something.
Where do i start on my trouble shoot?! Thanks in advance guys Smile
al kaline
Re: Windscreen wiper wipe out
Post by scotia on Fri Nov 17, 2017 5:40 am
so is the problem a spilt second numbing of power or the wipers not working anymore.
numbing of power:
the litle/thin wires comming from the battery could be the problem.
but it could be your battery itself to
wipers:
does it make any noise anymore dispite not working?
check fuse?
i hope somebody else can give you some better advice
im just trying to respond with what comes to mind.
i have no idea what im talking about , i just woke up drunken
Post by Raggy on Fri Nov 17, 2017 6:45 am
Check the connection to the battery by the two small wires. I found this out the other week, I had moved the battery a touch and found nothing worked, then discovered that the end connection had just corroded and broken off. Maybe yours is breaking. Worth a quick look.
Post by al kaline on Sat Nov 18, 2017 10:48 pm
It was weird. I turned her on the following morning and the wipers were working again. I checked the battery all looks normal. I wonder what could have caused that sort of behaviour..?
al kaline
Post by PFM on Sun Nov 19, 2017 1:06 pm
Sounds like an dodgy connection somewhere, usually working but occasionally not. Small wires from battery worth checking.
Post by Logi on Sun Nov 19, 2017 5:40 pm
L H side of the column, connection below fusebox, give it a clean, mine went a similar way.
Post by al kaline on Thu Nov 23, 2017 8:46 am
Nice one chaps Cool this one had me worried.
al kaline
