The oil light is on but shes full?
Page 1 of 1 • Share •
Went to go for a quick spin and upon ignition, the oil light stayed on. I stopped, topped her up to level full. Turned her back on but the little red oil light is still lighting away at me. I drove her for a bit slowly out of curiosity and observed a certain lack of power in her push and also a slightly different noise to normal from the engine so I turned around. Have any of you guys ever encountered anything like this? Yikes. I hope it's nothing serious.
al kaline- Chatterbox
Re: The oil light is on but shes full?
Wondering if this is possibly related: She's been leaking oil for a while. Just a few spots on the drive way here n there. Been down to have a look but it's hard to tell where from as the previous owner covered the whole underside with some sort of oil - probably to hide the rust, I don't know. Also she hunts on idle (not sure if that could be related)?
I would say most likely that the fault is with your Oil Pressure Switch. I have seen it quite
a few times. Unlikely to be the oil pump. Just to be safe get someone to take you to a local Motor Factors and get a new one. Shouldn't be any more than a Tenner. The switch is located right next to the oil filter. You may need to remove the plastic under tray that is held on with 3 10mm set bolts. Try not to snap them. If they do move a bit then undo the set bolt then re tighten gently then undo just working it back and forth gently.
I had to remove my very rusty battery box yesterday and those set bolts almost always break. But with patience and liberal amounts of WD40 all four came undone.
I feel pretty confident that is your problem and easily resolved. But I have been known to be wrong, but not usually about oil switches.
Ah, slight misunderstanding Al. I thought that you had a 1300 van. Being perfectly honest I have forgotten where the oil switch is on a 993cc. It's almost 2 years, 2 strokes, one fire, and diabetes all to contend with since I last pulled a 993cc to bits. Raggy will know, won't you Raggy? Raggy?? RAGGY!!! COME BACK YOU COWARD.!!
Now if you had said water temp sensor I would have been your man! I’ll have to have a look where the oil sensor is. I’ll get back on here as soon as I find out.
Raggy- Jet Addict
Raggy- Jet Addict
ahh thanks a ton for this, that little drawing does resemble the part ive got along with 42 - a little wire that comes off of it. So would i just have to remove my seat to get to it? or remove the oil filter too? thanks again!
No, I have to remove the seat just because I cant tilt it back in mine as I have rear seats built in as its a camper.
Raggy- Jet Addict
That is a Vacuum take off. It has a pipe on it. Oil pressure switch has a spade terminal connected to WIRE not pipe Al.
Oil pump on the 1300 is at the front of the engine directly behind the front pulley and Cambelt. Have a look at the front area of your Cambelt cover. It may well be there. I'm sorry I just can't remember much about the 993cc engine. Hardly ever worked on them. Just scrapped them 95% of the time.
I just cant seem to find it anywhere
cant even really see the oil filter support arm properly let alone access it if the part is on there, looks like id have to take out (what i assume) is the air filter... My mechanics is terrible.
Ive spoken to a few mobile mechanics to see if i can find anybody within my budget to come out and yiikes these guys are expensive round here. They are all also telling me that if i drove with out oil pressure ive most likely caused serious damage. I did experience a loss of pressure when i drove her and a different slightly more "metalic" sound. Also the other day when looking around under the seat for this switch i turned the engine on and it wouldnt start - something it has never struggled with before... im scared.
Page 1 of 1
