Piaggio Porter 2007 van Oxygen Sensor
Page 1 of 2 1, 2  Next
Post by MerlynHolmes on Fri Dec 01, 2017 5:02 pm
.....can someone please help. I'm looking for an O2 sensor for my little van. I ordered one from Germany, but it doesn't fit, so will have to go back. So far the only other quotes I've had are in excess of £150 and not on the affordable scale. Does anyone know if any of the universal sensors will fit and if so, which? It's a 1.3 petrol with LPG conversion.....and that's a whole other story.
MerlynHolmes
Re: Piaggio Porter 2007 van Oxygen Sensor
Post by scotia on Sat Dec 02, 2017 9:51 am
you could ask/email this shop
https://www.apewebshop.nl/index.php?item=piaggio-porter&action=page&group_id=27&lang=nl
and this site has a lot of parts to
https://www.mondoporter.com/
thats all i can do for you
good luck
Post by MerlynHolmes on Wed Dec 06, 2017 7:10 pm
....thanks for that....still too expensive though
MerlynHolmes
Post by Woodie on Thu Dec 07, 2017 11:14 am
Like these ones for £50 +£5 First Class signed for you mean?????
Post by MerlynHolmes on Thu Dec 07, 2017 3:43 pm
.....will they definately fit my van? I already bought one from Germany and it said on the web page it would fit and it doesn't.
MerlynHolmes
Post by Woodie on Thu Dec 07, 2017 4:15 pm
Do you mean the thread size is wrong as in "doesn't fit"?
Post by MerlynHolmes on Thu Dec 07, 2017 4:27 pm
....yes, I believe so, although the chap at the garage didn't go into great detail.
MerlynHolmes
Post by MerlynHolmes on Thu Dec 07, 2017 4:30 pm
.....just spoke to him and he said it was the plug that didn't fit, not the thread
MerlynHolmes
Post by Woodie on Thu Dec 07, 2017 4:41 pm
Is he totally brainless?? Most Lamda sensors come without a plug. You merely cut the wires and join them with crimp bullet connectors. Has he also realised that there are TWO Lamda Sensors, one on the exhaust manifold and one on the Silencer just behind the Cat.
Post by MerlynHolmes on Thu Dec 07, 2017 4:58 pm
....hi, yes, I thought that too. I did suggest he put the old plug on the new sensor, but he said there's no guaruntee it would work? And yes, he did suggest that I get two sensors, but it's only one that's showing up as faulty on the diagnostic thing
MerlynHolmes
Post by Woodie on Thu Dec 07, 2017 5:02 pm
Just two words for him..... Incompetent Idiot. Can't deal with people like that.
Post by MerlynHolmes on Thu Dec 07, 2017 6:48 pm
.....so, should I just tell him to go ahead and swap the plugs? Will that definately work?
MerlynHolmes
Post by Woodie on Thu Dec 07, 2017 10:01 pm
Seems to me that he has got the hump with you because you have supplied the part thereby introducing a third party into the equation.
I loved it when customers supplied their own new parts. If there was a problem with it the customer had to pay me to remove and replace it and I didn't have the aggravation of dealing with the supplier which cost me time and money.
If he can't do a simple job like that then he should be cleaning lavatories or something worthwhile of his incompetent lack of skills. What's his name?? Definitely not Jean- Michel Jarre?? I think not. He's certainly no OXYGENE-ius is he. If he can't sort that, find another local garage that can.
Post by GEORDIE on Fri Dec 08, 2017 12:32 am
trouble is Woodie there are mechanics and fitters,if it wont fit out of the box its the wrong part!!
GEORDIE
Post by Woodie on Fri Dec 08, 2017 7:39 am
You are so right=Geordie. It just beggars belief that some Trained Mechanics cannot join 4 wires together. But as you say they aren't Mechanics - - Just a fitter of parts.
My six year old Grandson has a Raspberry Pi. Computer and the gadgets he has working off that amazes me. He learned how to use his mobile phone as a TV remote when he was 3. He would have no problem with sorting out Mr (P)OXEGENE the Hopeless Twitter. Must be a mate of Donald Trump.
Post by MerlynHolmes on Fri Dec 08, 2017 2:06 pm
....ok, so will I tell him to swap the plugs over then? Also, can you please tell me if there is any difference between the two oxygen sensors? Thanks
MerlynHolmes
Post by Woodie on Fri Dec 08, 2017 2:13 pm
To the best of my knowledge they are both the same. Overall dimensions, Thread size, connector plug, 4 wires, all the same Merlyn.
Post by MerlynHolmes on Fri Dec 08, 2017 3:52 pm
.....so, I just spoke to him and he says that the wires on the new sensor are different colours to the old one and he has no reference as to what colour connects to what. He says to call back on monday and he'll tell me what the colour sequences are......would you be able to help with this?
MerlynHolmes
Post by Woodie on Fri Dec 08, 2017 9:51 pm
Tell you what. You buy the other Oxygen Sensor from me and I will wire it with the original Daihatsu plug and then your idiot Garage can use it as a pattern for the other one he got from you.
Post by MerlynHolmes on Wed Dec 20, 2017 4:58 pm
Hi there....sorry, I've been quite ill and out of action. Needless to say the issue is ongoing! Anyway, the wiring is as follows: old sensor = 2 black, 1 blue, 1 white. New sensor = 2 grey, 1 black, 1 white. Instinct tells me that the following is the most likely to work: 2 grey to 2 black, black to blue, white to white.....is this correct? I imagine that the only thing that could be wrong is the black to blue and white to white, in which case it would show up on a diagnostic scan and if so, swap these two over. This appears to be ridiculously simple, but then again, what do I know? I'm just a wummin who upsets car mechanics and buys them shortbread by way of appology! He'll not even get a custard cream for this!
MerlynHolmes
Post by Woodie on Sat Dec 30, 2017 4:45 am
I loathe this site's inability to save posts in progress. I have just written an in depth reply and suddenly - its gone.  It really makes me feel like swearing, something I don't do on Public Forums. At home in my garage if I hurt myself I have been known to utter a few expletives.
But anyway, starting all over again I will be brief- has your Garage worked out which wire goes where??  If he hasn't, please let me know at thehijetmaniow@gmail.com and I will dig out a Lamda Sensor and sort out the "which  wires to where" syndrome for you.
Post by Woodie on Sat Dec 30, 2017 4:54 am
YET AGAIN!!! I loathe this Site's inability to save Posts in progress. This is the THIRD attempt. This is a new phone and it is so sensitive and rapid and with my bear traps for hands and Pork Sausages for fingers - it's not a good combination. I usually use my Tablet, but it is out in the garage for streaming Music to my Bluetooth Speakers out there.
Basically has your Garage been able to sort out The Mastermind Challenge? If not can you let me know on here or at my email address :
Post by Woodie on Sat Dec 30, 2017 4:55 am
Flipping hooray!!! Third time lucky. Well I am blowed - the second one DID get through.
Oldie - don't you dare - bog-off!!!
I'm coming up to see my Mum in Merthyr Tiddfyl in the New Year. You don't want me and my Bear Traps to be paying you a visit do you??
Post by oldie on Sat Dec 30, 2017 6:05 am
It's Merthyr Tydfil Wink , I used to run a pub in Merthyr called the Great Escape which was just further up the road from the Fire Station.
Did you know Merthyr was once the white sock capital of Britain Very Happy ....
http://news.bbc.co.uk/1/hi/wales/2701837.stm
The Dutch have no style though Laughing .....
http://news.bbc.co.uk/1/hi/wales/3396443.stm
Hmmmm....what can I say  lol! ....
https://www.amazon.co.uk/Never-White-Socks-Merthyr-Tydfil/dp/0955530601
Post by Woodie on Sat Dec 30, 2017 6:11 am
Great!! When you start taking the Mickey - at least I can say now "Put a sock in it Oldie" appropriately.
I will let you know when we are coming up to see mother, and if you are game, meet up for a Coffee and a chat.
Post by oldie on Sat Dec 30, 2017 8:36 am
Ha!...I'm not actually from Merthyr  tongue , only there while running The Great Escape pub .
Just looked on Google Maps...the pub has long closed and now seems to be a funeral home.
Pub.....
https://www.google.co.uk/maps/@51.7489157,-3.3853535,3a,75y,240.93h,85.23t/data=!3m6!1e1!3m4!1sHPxKl5bB8T6iN8k9dUTbdw!2e0!7i13312!8i6656?hl=en-GB
Funeral Home....
https://www.google.co.uk/maps/@51.7488857,-3.3853978,3a,75y,179.45h,88.42t/data=!3m6!1e1!3m4!1s5l-2Tz0FSx5BBU713nfCwA!2e0!7i13312!8i6656?hl=en-GB
Post by Raggy on Sat Dec 30, 2017 10:46 am
Well thats appropriate for Woodie, hes closer to getting in there than most of us!
Post by oldie on Sat Dec 30, 2017 12:24 pm
Raggy wrote:Well thats appropriate for Woodie, hes closer to getting in there than most of us!
Shocked   Shocked   Shocked   Shocked .......well' that's just shocking Wink Laughing .
Wasn't me.....I never said it..... wouldn't dream of it......nothing to do with me Mr Woodie ....honest Very Happy  lol! .
Post by Raggy on Sat Dec 30, 2017 1:11 pm
Razz Just saving you from the flack as I beat you to the comment
Post by MerlynHolmes on Fri Jan 12, 2018 1:25 pm
Hi there Woody. I replied to your email, but not heard back from you. Anyway, here is a copy of my message:
No, the guy at the garage has not been in touch, so I presume he's not sorted it. As I said, the wire colours on the old sensor are 2 black, 1 blue and 1 white. The new sensor wires are 2 grey, 1 black, 1 white.
Sorry I've not replied before this, but I've been quite ill these past few weeks....first time I've ever lost weight over the festive holidays! I hope you had a grand time yourself and any help you can offer would be much appreciated.
Kind regards
Merlyn
MerlynHolmes
