Skylark Spoiler
Skylark Spoiler
Post by Raggy on Sun Feb 11, 2018 5:16 pm
Eventually braved the cold in the garage to make a start on the rear spoiler for Skylark. Its based on one done previously by HJ but I am going to retain the central high stop light. The original spoiler is a Suzuki Ignis one that is you are lucky you can drop on them quite cheap on fleabay which is where mine came from. They are a nice match except they are too wide so a bit of chop chop (as the Mighty Car Mod guys say on Youtube) is required.
The spoiler when cut will match the existing ridges on the roof.
Spoiler fit for a Suzuki Ignis
Dimensions if anyone else fancies a go, measure twice cut once.
Spoiler now fit for a hijet
Tried it up to the van and a perfect match but I think a bit of strengthening at the joint lines is required as the masking tape seems to be a bit 'fragile' for a permanent solution Very Happy
Updates as soon as I brave the cold weather again!
Re: Skylark Spoiler
Post by Raggy on Tue Feb 13, 2018 10:42 pm
A little bit done in the garage and now I have thawed out I'll post the pics. Started to fix the shortened spoiler back together a bit more permanently. Used some plastic strips as bridging pieces across the join inside the spoiler. Glued them with polyurethane adhesive then screwed them through. When both ends are done I'll plastic weld the joints together as well. So far so good and well pleased with how they have aligned. Remembered to put some tube through for the cable for the lights...could have been a disaster if I had forgotten that as no spare room inside with plastic strips in to get a cable through afterwards!
Re: Skylark Spoiler
Post by Raggy on Sun Mar 11, 2018 11:02 pm
In the wrong order the pics but this is the modified fitting to change the profile of the spoiler to match to hije5 rear door. Filler used for the outside and the middle to be filled with fibre glass and matting mix.
First fitting of the modified spoiler, not bad at all. Needed to do this to get the fitting correct and to set up the reversing camera that I have fitted to the spoiler. No guessing now how close I will be to something now.
The spoiler supports being moulded to fit the rear door profile to make it a better fit.
Next job to finish off the support mouldings, rub it down, prime it, sort out how to get wires to it and how to get access to the fixing bolts would help! Current feeling is to finish it in silver like the pop up roof but could also be blue to match the rear door....decisions...preferences anyone?
Re: Skylark Spoiler
Post by Raggy on Tue Apr 10, 2018 12:14 pm
Know this has been quiet for a while but the update is I nearly got to the point of spraying it....then I dropped it on its end and it cracked the filler so had to refill that...oops! Hung it up to spray, turned my back and the hook I put it on gave way Grrrrrr. Any way I'll post an update soon when I get back on it. Should have plastic welded the joints where I shortened it and I bet it would not have cracked then but though the joint as I had done them were OK, which they are for normal use just not dropping it on its end! Oh well, live and learn.
Re: Skylark Spoiler
