Engine change
Engine change
Post by Tractormass on Tue Mar 06, 2018 11:59 am
Hi all new to this forum
I have a 2005’piaggio tipper which froze up in the recent weather and has cracked the block my question is will a diahatsu engine fit as I know of a wrote of one they are both 1.3 16 valves
Thanks for looking
Tractormass
Re: Engine change
Post by kernowjon01 on Wed Mar 07, 2018 11:06 am
Same vehicle - if you look at the VIN number stamped on the HiJet you will see it has the Piaggio VIN number. Daihatsu (by that time was marketting). If I were you I'd change the engine loom and ECU to avoid problems.
Jon
kernowjon01
Re: Engine change
Post by PvdB on Wed Mar 07, 2018 12:05 pm
Hello tractormass,
I recently started a topic about different 1300 engines. There are differences between Daihatsu engines. I would assume that your Piaggio Porter uses the latest engine.
Share some pictures, that always helps!
PvdB
Re: Engine change
