Tick over adjustment
Post by Tukz on Sat May 28, 2011 9:31 pm
Hi, can anyone tell me how to adjust the tisk over on a Daihatsu Hijet 1.0l EFI?.
Tukz
http://www.tuktuktravel.co.uk
Re: Tick over adjustment
Post by rich the mechanic on Mon May 30, 2011 8:58 pm
Right you need to be on the right hand side of the engine look at the top of the throttle body towards the front there is a half inch rubber bung remove and a cross head screw is below run enginge to normal running temp and adjust as required cant remember which way does what but as you have fitted the engine yourself I'm sure you can work it out Laughing
Post by Tukz on Tue May 31, 2011 8:56 am
Thanks very much for that. I looked at that rubber bung andthought to myself mmmm wonder if there's anything underneath that!. should have taken a look I suppose. Oh well, I will get it done today.
Thanks again
Scotty
Tukz
Post by Logi on Sun Jun 05, 2011 12:02 am
Is it a similar thing on the 1300?
Post by rich the mechanic on Sun Jun 05, 2011 8:02 pm
I don't know but would be suprised if it's not.
