replacement rad
replacement rad
Post by carljames on Mon Apr 30, 2018 5:22 am
Hi
I recently bought a front damaged 04 hijet van.
I needed a rad and seeing they were around £175 i decided to find a replacement.
I settled with a Honda Civic 3 core aluminum half rad with a built in fan.
to fit I had to re position the lower hangers and put an angled bracket on the floor fixing, i had to also lengthen the top mount and move it over slightly.
The honda rad has a top hose so i had to use a 90 deg hose and an angled joiner pipe. to slide the fan in i needed to panel beat the channel a bit to make it wider. on the whole it looks well.
if a standard civic rad was used i think it would slide up without any modification to the channel
carljames
Re: replacement rad
Post by carljames on Mon Apr 30, 2018 5:25 am
carljames
