Hi from leicester
Page 1 of 3 1, 2, 3  Next
Hi from leicester
Post by carljames on Mon Apr 30, 2018 9:09 pm
Recently purchased a 2004 hijet 1.3, front end damage . paid £255 so can afford to mess about with it.. It is a runner and drivable but only to drive on and off a trailer as the rad is damaged
carljames
Re: Hi from leicester
Post by carljames on Mon Apr 30, 2018 9:21 pm
not too bad nick on the whole
carljames
Post by carljames on Mon Apr 30, 2018 9:27 pm
Front stripped , dent pushed out with a power ram, then a slide hammer was used to
get back as much profile as possible, a skim of fibre filler was used to get a basic shape
then polyester filler was used to achieve the required shape
carljames
Post by carljames on Mon Apr 30, 2018 9:30 pm
crumpled footwell straightened out
carljames
Post by Raggy on Tue May 01, 2018 6:43 am
Keep the updates comming
Post by scotia on Tue May 01, 2018 7:23 am
nice work Smile
Post by carljames on Tue May 01, 2018 1:12 pm
fitted a Honda civic 3 core rad , had to widen the channel as the rad is thicker than the original. used the original hangers but had to re-drill the front mount holes but added a bracket to pick up the original floor holes.
carljames
Post by Scarface GTti on Tue May 01, 2018 2:09 pm
Good work, keep the pics coming!
Scarface GTti
Post by carljames on Tue May 01, 2018 7:03 pm
The jobs on hand at the moment are: final prepping of the front ready for colour , taking the dash back out to connect the heater fan plug, doh.... and removed the drivers door glass as its come off the runner clamps
carljames
Post by carljames on Tue May 01, 2018 7:38 pm
carljames
Post by Raggy on Tue May 01, 2018 9:52 pm
That looks a nice job
Post by carljames on Wed May 02, 2018 5:33 pm
first coat of colour
carljames
Post by carljames on Wed May 02, 2018 6:11 pm
second coat of paint and then covered over.....
carljames
Post by Raggy on Wed May 02, 2018 6:20 pm
Nice
Post by carljames on Thu May 03, 2018 6:01 pm
yet again another part that was supplied with the van 'to repair ' is damaged.. the grill supplied had one of the lower locating lugs broken off, being as it needed spraying i decided to repair it, made a lug out of aluminium ( used the good one as a template )
riveted and bonded in place then built it up with resin
and then sprayed...
carljames
Post by carljames on Thu May 03, 2018 6:05 pm
carljames
Post by Raggy on Thu May 03, 2018 6:12 pm
Has it got the top clips that hold it to the van?
Post by carljames on Thu May 03, 2018 7:36 pm
yes they are there. just put the headlights on and the reflectors are discoloured.. may need to replace them for the Mot.....
carljames
Post by carljames on Fri May 04, 2018 5:55 pm
the headlights supplied with the van to replace the damaged one were no good , too much of the reflector had deteriorated. I have managed to repair the drivers side light which has a very good reflector. as for the passenger one it had slight reflector damage but i have use a paint bud and some chrome paint and touched it up. seems to be ok
carljames
Post by carljames on Fri May 04, 2018 6:02 pm
painted the headlight surrounds at work
carljames
Post by PFM on Fri May 04, 2018 6:56 pm
Looks like you're doing a quality job there, looking forward to seeing it finished!
Post by carljames on Fri May 04, 2018 9:53 pm
couldn't connect the rad up as the hose joining tube hasn't arrived yet... Then i noticed a Momo steering wheel hanging up in the garage which was on a Honda civic I'd bought for its engine.... So spent the evening with modifying it to fit the van, after a few trial and errors got it all sorted , ended up having to open out the column cover hole to allow the adapter to contact the horn terminal. also managed to get the indicator cancel to work on it.
carljames
Post by carljames on Fri May 04, 2018 10:55 pm
PFM wrote:Looks like you're doing a quality job there, looking forward to seeing it finished!
Thanks, just a shame i ordered solid paint and not metallic, just overlooked it...
carljames
Post by Raggy on Sat May 05, 2018 9:43 am
Paint rest of van solid to match?
Post by carljames on Sat May 05, 2018 6:48 pm
was considering it, small wheel arch repairs needed soon so probably will.... fronts all done.. just door glass to fit and fog light to get working
carljames
Post by carljames on Sat May 05, 2018 6:51 pm
rads working a treat, fan comes in at 3/4
the fuel lights been taped over so i assume the sender isnt working
carljames
Post by Raggy on Sat May 05, 2018 9:21 pm
I assume the light comes on and taped to stop annoying. Could be an easy fix as apparently the float comes out of its tube sometimes but... requires the tank to be dropped to get at it and some of the pipes can be rusty so do it when you do t have much fuel in. You can’t not fix it now you have done so well so far.
The window is an easy enough fix, just clean up the plastic brackets that hold the glass then glue them back to the glass with PolyUrethane adhesive I.e Tiger Seal etc. I did try Gorilla glue...rubbish....Tiger Seal just the job, not had an issue since.
Post by carljames on Sat May 05, 2018 9:54 pm
already done the drivers with propper window adhesive our window fitter uses for bonded windows.
going to put a tint on them too..
carljames
Post by carljames on Mon May 07, 2018 7:01 am
Driver window covered with window film and re fitted
Fitted a new fog light unit and its now working, couldn't see anything wrong with the old one
carljames
Post by scotia on Mon May 07, 2018 9:13 am
im not the kind of guy who starts screaming "thats illegal" directly
but i dont think tinting those windows is a good idea
besides what the police might think of it its verry dangerous
ive done it to in the past and removed it because i almost killed som people on bicycles
they were riding them at night without lights and didnt see them because of my dark tint
and another thing you have eyecontact with a lot of the other traffic when lets say a car or bike or a pedastrian comes to you from the side... he/she wont be able to see you with those windows
offcourse those people on bikes should have their lights on but i think you will still feel verry bad after you put somebody in a wheelchair
no matter if you were in the right or not.
go drive it at night outside of town without streetlights and then tell me you still feel its a good idea
