Hi from leicester
Page 3 of 3 Previous  1, 2, 3
Re: Hi from leicester
Post by kernowjon01 on Sat Jun 16, 2018 12:15 pm
It is not unusual for a new belt to need readjusting after a short while.
Readjust and if all is OK it is job done - don't go too tight or you will also get squeal and damage bearings.
Jon
kernowjon01
Post by carljames on Wed Jun 20, 2018 11:10 am
tightened the belt a tad.. ok now..
next job fitting a Tacho , bought one off ebay , mounted now just the wiring to sort..
carljames
Post by Raggy on Wed Jun 20, 2018 4:22 pm
Now thats nice, got a link to it?
Post by carljames on Wed Jun 20, 2018 4:30 pm
carljames
Post by Raggy on Wed Jun 20, 2018 4:42 pm
Ah, forgot yours is the 1.3 so an extra cylinder to mine. Looks good though.
Post by kernowjon01 on Thu Jun 21, 2018 5:12 pm
kernowjon01
Post by Raggy on Thu Jun 21, 2018 6:51 pm
Not as nice as a dial though.
Post by carljames on Sat Jun 30, 2018 12:49 pm
me again ...
popped in work today.... was going to fit a universal dip sender to the tank but it is a bit short, so instead i decided to fit a spare carbon bike silencer i have to the van..
First job was to modify the cat so its positioned at an angle , welded a bend to the can and fitted the lambda sensor to it, modified the silencer mounting strap so it can pick up one of the van hangar bars and fitted a rubber do-nut.
the silencer comes out just before the rear wheel, its sounds deep and like a bike....
carljames
