hijet 1300 efi none starting
Post by davidc on Thu Jun 02, 2011 1:25 pm
hello can any one help i have a hijet 1300 efi and it has no spark any ideas ived changed the ecu still no spark thank you
davidc
Re: hijet 1300 efi none starting
Post by rich the mechanic on Thu Jun 02, 2011 10:35 pm
obviously there is shit loads it could be Exclamation Does the 1300 still have a dizzy if so is it pluged in, is the rotor still in one piece has the cap broken and are all the leads plugged in properly and daft one you are earthing the plug to the engine when testing to make a curcuit Laughing
Post by davidc on Fri Jun 03, 2011 9:42 am
it is a late one with coil pack there is power to the coils but it not firing in to spark thank you
davidc
Post by rich the mechanic on Fri Jun 03, 2011 10:42 pm
Right the coil discharges (sends spark to plug) when the power stops is the dizzy rotor spinning?
Post by davidc on Sat Jun 04, 2011 12:30 pm
i have just found whats up with it the camshaft has snapped
davidc
Post by PFM on Sat Jun 04, 2011 1:49 pm
Glad it was nothing major! Shocked
Post by rich the mechanic on Sun Jun 05, 2011 8:05 pm
Where has it snapped? and has it seized up.
