Ariel - Recomendations
Post by Raggy on Fri May 11, 2018 12:12 pm
I replaced the Ariel on Skylark when I got her but have found that the reception is sometime rubbish. The areal does tend to fill with water I have found when you collapse it down it squirts out. Any recomendations for a good areal that will fit in the usual place on the windscreen pillar?
Re: Ariel - Recomendations
Post by PFM on Sun May 13, 2018 1:25 pm
Try Persil instead! Very Happy You used to be able to get universal pillar-mount aerials, not sure if still available. However, if analogue is switched off you'll need an alternative then for your new DAB radio.
Post by Woodie on Sun May 13, 2018 2:54 pm
And as a Laundry Business Owner PFM would definitely know Raggy. I went on Amazon a couple of years ago and bought 10 Areials from London. They were cheap but not Cheap and Nasty. Inevitably when you get a Hi-Jet, the Areials are broken, so fitting a new one tidies up the front for a couple of pounds.
DAB?? Steady on PFM - some of us live out in the sticks - not Posh Places like Eastbourne.
Post by Raggy on Sun May 13, 2018 3:32 pm
DAB! Nothing so fancy! Was a cheap one I got but mine was probably really cheap knowing me! Will have a look see what I can find.
