Where do i get piaggio porter parts from???
Post by Nomadnat on Tue Jul 03, 2018 4:08 pm
Hi guys,
Bought this on ebay without thinking through. After pucking it up in durham it has broke down twice n that was just on the way home!! Ive not even used it yet. The latest replair needed is the diff seal rear axel. Can anyone advice where i get the parts from as my garage laughed me out the door!
Nomadnat
Re: Where do i get piaggio porter parts from???
Post by Raggy on Tue Jul 03, 2018 7:32 pm
Then get a new garage!
Try Knightcott Motors Weston Super Mare Can Supply Parts for Daihatsu Hijets and Piaggio Porter Models
We Also Supply NEW Genuine Piaggio Parts
Tel: 01934 822335 Mobile: 07836 770259
Possibly expensive but genuine parts that cant be sourced from ebay or vans being stripped.
Post by biofos on Wed Jul 04, 2018 2:50 am
Can you be more specific about your description 'diff seal, rear axle'. Is it the square cork seal behind the tin plate facing the rear of the van, centre of differential? Or do you mean the bearing seals half shaft to rear wheel carrier, or the prop shaft to diff seal?
The former could be repaired with 'seal in a tube' until a proper cork gasket is obtained. Bearing seals may be available from bearing specialists.
I've dealt with the two main Italian Piaggio suppliers and they are very good. But you need to order quite a bit of stuff as their carriage is quite pricey at €20 regardless of size. Drop me an email for more details.
biofos
http://www.biofos.com
Post by Buffy54 on Fri Jul 06, 2018 10:32 pm
Raggy wrote:Then get a new garage!
Going in my notes, thanks Raggy
Sent from Topic'it App
Buffy54
