Engine swap ideas
Engine swap ideas
Post by Brainsparks30 on Sat Jul 07, 2018 11:59 pm
Seeing as how the engine appears to be the weak point in Hi-jets, has anyone done an engine swap? I was thinking of a motorcycle engine, something simple and tough with good parts availability. How about air cooled?
Even a diesel could be considered.
Most of the cheap vans on Ebay have engine issues and I like to make stuff.
Brainsparks30
Re: Engine swap ideas
Post by rwd on Fri Jul 13, 2018 6:11 pm
Ive just stripped out my van and stripped a Kawasaki zzr1100 for the engine. Should be fun when ive done it
rwd
Post by Brainsparks30 Yesterday at 10:49 pm
I'd be quite keen to see the progress on that.
The bit that boggles me most is how to adapt the drive between new engine and existing transmission.
Brainsparks30
Post by Woodie Today at 9:25 am
More to the point, how do you get over the embarrassment of having to get out of the cab and push it backwards into a parking space in the middle of the High Street, especially up a slope??
Not an easy solution to find a way for having a reverse gear.
The old Bond 3 wheelers that had 2 stroke engines and could be stopped and the engine would run backwards so had 4 reverse gears in effect.
Unfortunately 4 strokes don't fare to well trying to run them backwards. Arrow Rolling Eyes
Post by kernowjon01 Today at 9:38 am
Woodie wrote:More to the point, how do you get over the embarrassment of having to get out of the cab and push it backwards into a parking space in the middle of the High Street, especially up a slope??
l:
There are solutions available - offered for bike engined kit cars - basically a little electric motor for reverse. But be aware they are quite pricey. I think it is probably easier to go the 1600 route - or the if you fancy a diesel go that route - I think it has the same cooling issues which are really related to the layout of engine, radiator and heater which can create airlocks. Without wishing to bore you all - I believe using tap water is asking for trouble, water companies add many chemicals and these can react with the materials which make the modern gaskett. Deionised water is about £1-50 for 2.5 litres and should be mixed 50/50 with antifreeze for a good coolant. Then carefully follow the filling and bleeding method on this site.
Jon
kernowjon01
