Lspv Valve needed
Lspv Valve needed
Post by Aij29 on Tue Jun 14, 2011 5:02 pm
Hi Guys
I`m after a good Lspv valve for my Hijet (failed Mot on rear brakes)
HELP!!!!!
Adrian
Aij29
Re: Lspv Valve needed
Post by 8bit-ash on Tue Jun 14, 2011 8:03 pm
Good luck with them, I had a pig of a job getting it through the MOT due to rear brake problems. Email www.hijetparts.co.uk. He sorted me out at a great price and quick delivery.
Post by Aij29 on Tue Jun 14, 2011 8:45 pm
Yeah he was the first guy i tried and hes out of stock for 2 weeks at least Shocked
Think i`m going to have to get a new one from Daihatsu Sad
Cheers
Adrian
Aij29
Post by 8bit-ash on Tue Jun 14, 2011 9:36 pm
Take a seat!
Post by Aij29 on Tue Jun 14, 2011 9:47 pm
£167 including vat Shocked Shocked Shocked Shocked
But without one the van is useless Sad
Aij29
Post by 8bit-ash on Wed Jun 15, 2011 12:51 pm
Better than I expected tbh, a wheel cylinder is £70!
Post by Aij29 on Wed Jun 15, 2011 10:35 pm
Hi
Ordered one today for £144.00 affraid
Cheers
Adrian
Aij29
Post by Megarett on Sat Jul 04, 2015 10:31 pm
Really? I only paid 60£ total for the shoes, cylendar and a fuel filter...
Ordered through euro car parts
Megarett
Post by waz on Sun Jul 05, 2015 2:58 pm
Megarett wrote:Really? I only paid 60£ total for the shoes, cylendar and a fuel filter...
Megarett, the last post on this was in June 2011.
Post by Megarett on Sun Jul 05, 2015 5:18 pm
Lol, I just looked at the subject not the dates..
Megarett
Post by Logi on Sun Jul 05, 2015 5:58 pm
Post by HighlyJetted on Sun Jul 05, 2015 6:44 pm
Wheel cylinders are about £18 each from euro car parts. I have just MOT'd 2 vans, they both failed on rear brake effort. Neither needed shoes, drums, a wheel cylinder or an LSPV
Simply by freeing the up arm, and adding tension to the spring using a spacer under the bottom cup on the rod. The rear brakes then work. The cause of fault is the arm pivot going stiff, and the springs getting rusted and weak.
I must have had getting close to 20 fail sheets for lack of rear brake effort. Yet they have never needed any parts replacing.
The other most common failure item is corroded rear brake pipes. I hate doing brake pipes, but at least its cheap as the materials are just universal copper brake pipe and flare nuts.
I get a phone call a week requesting an LSPV. Sometimes owners, sometimes garages.
Post by andy pyke on Sun Jul 05, 2015 9:15 pm
I'm trying to persuade my mechanic to have a go at freeing mine up or as suggested on another thread. Standard response in most cases is "get a new one". Little do they know.... Smile
andy pyke
Post by Megarett on Sun Jul 05, 2015 9:25 pm
The bleed valve and be of the flare nuts is stripped...
Making it very hard to bleed. Suggestions?
Haha I'm like Frankenstein!!! There has been lots of lightning lately!
Megarett
Post by Logi on Sun Jul 05, 2015 9:28 pm
Megarett wrote:The bleed valve and be of the flare nuts is stripped...
If it's on a cylinder just replace it, saves a load of aggro
http://www.eurocarparts.com/ecp/c/Daihatsu_Hijet_1.3_2001/p/car-parts/brakes/brake-hydraulics/wheel-cylinder/?134560228&1&aee0f31c574b35b37a93b42a39e2b9e095f7d497&000371
And remember use "TWEET5" for 5% extra off Smile
Post by Megarett on Sun Jul 05, 2015 10:29 pm
It's on the LSVP...
Megarett
Post by Megarett on Sun Jul 05, 2015 10:30 pm
Sweet!! Deal on parts!!! Thanks!
Megarett
Post by HighlyJetted on Mon Jul 06, 2015 6:23 pm
Firsly you make it the problem of the moron that stripped it in the first place.
And if they fails you find someone who surpasses the 2.5 braincell barrier to resolve it.
Patronising mode off.
Flare nuts undo if you warm them up then get them with high quality mole grips. Non of those chinese or cheapo wank ones. This is a one shot purchase game, every time you fail to undo it and chew it up more, the lower the chances of getting it out in one piece is.
Broken bleed nipples come out again if you heat them up till they cherry, then either bite the remained with mole grips, and if they are totally sheered you gently try using easy outs.
The worst possible outcome is snapping an easy-out in the hole. Cos you can't drill those bastards as they are very hard. A fool with a set of easy-outs is a dangerous thing. The user must know their limits.
If that fails you have to drill and heli-coil.
Before you do any of this stuff, you wire brush it all back and keep soaking it with plusgas for as many hours before hand as possible.
Any garage worth using will know all this school boy stuff.
Post by Megarett on Mon Jul 06, 2015 6:39 pm
The guy who stripped it is a terrifying man from Liverpool... I value life so I'll leave him alone...
Thanks for the tips!! It's already been soaking in lube for days, will purchase some nice vice grips and giv'r a go ( as we say where I'm from).
Megarett
Post by HighlyJetted on Mon Jul 06, 2015 6:44 pm
Post by HighlyJetted on Mon Jul 06, 2015 6:45 pm
Also, I cut the brake pipe to the flare nut I am trying to undo.
Then if possible I hammer a socket onto it, a size smaller, sometime imperial.
Post by Logi on Mon Jul 06, 2015 7:08 pm
Post by Guest on Tue Jul 07, 2015 9:08 am
A Dog is a man's best friend?? Nope!! Definitely my Rothenberger Gas Torches.
One at my workshop, one at home with all my Plumbing gear.
Post by Logi on Tue Jul 07, 2015 1:09 pm
Though to be fair dogs burn pretty well too... Wink
Post by Guest on Tue Jul 07, 2015 6:26 pm
Chinese seem to enjoy them anyway.
